Author Topic: How to create a new port for temp gauge probe? Using a Sniper t-stat  (Read 4680 times)
fairlaniac
I'm about done installing my Sniper 4150. I am not using a lot of the extra features as I just want to get it running. I have a Performer RPM intake and am using one port behind the distributor for the Sniper t-stat and I have my heater connection on the port behind the radiator t-stat. I have a t-stat housing with port for my electric fans. I want to keep my fans controlled by it's own t-stat at this time. I also want to run my mechanical temp gauge into a port but I'm out of places. Any ideas? I bought this bypass in the picture below per an article I read on Vintage-Mustang however the temp gauge probe completely blocks off the flow to the heater hose if I use it in that location. I don't want to drill and tap my intake because I may use other features down the road. So, what other creative ways could I create a port for my temp gauge?
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
ToddK
Re: How to create a new port for temp gauge probe? Using a Sniper t-stat
« Reply #1 on: August 18, 2020, 07:51:56 PM »
Are you using an aftermarket aluminium radiator? I have a fitting near the inlet neck of my radiator that I use for the temperature switch for the electric fans. That could be an easier option than disturbing the intake manifold.
« Reply #2 on: August 18, 2020, 10:50:54 PM »
Doug, I'm not sure which style of gauges you currently have and if you're willing to spend the extra money for it, but I went the electric route for water temp and fuel pressure. I have the AutoMeter Ultra Lite II 2 5/8" gauges. Anyhow, the sending unit is 1/8" NPT. I didn't want to piggy back fittings, so I decided to drill and tap my RPM intake for the added sensor, since I also have a heater fitting in use and another for the electric fan sensor. I used my sonic checker to find a safe location and where it was accessible to tighten/loosen the fitting. IIRC, the thickness was around .240" and seemed like plenty of thread engagement for 1/8" NPT. I decided on here:
« Reply #3 on: August 19, 2020, 07:32:42 AM »
« Reply #4 on: August 19, 2020, 07:38:58 AM »
A couple other options, but you'd have to research thread size etc.
https://www.amazon.com/Motormite-47993-Heater-Hose-Connector/dp/B078XKG7Y3
https://www.amazon.com/Ford-E5TZ-18599-C-ELBOW/dp/B000O0VIAM/ref=pd_lpo_263_t_1/136-3866780-6246036?_encoding=UTF8&pd_rd_i=B000O0VIAM&pd_rd_r=96f258d5-a28e-440c-90c7-3f02e049b869&pd_rd_w=lFayQ&pd_rd_wg=KvwmK&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=YC3BNZE3NS9Z9MSYZX7D&psc=1&refRID=YC3BNZE3NS9Z9MSYZX7D
Also, if you do have flow, but the heater hose is restricted, I wouldn't worry too much.  It doesn't take a lot to keep the inside warm and hot water flows like gangbusters.  In fact, I typically epoxy a standpipe into the ID of an aftermarket fitting to avoid steam pockets and restrict the heater core.  It helps your heater core live when you do a high speed blast and/or start purging the system at fill.  At worst, you won't have heat, it sure won't hurt the heater or engine, all it does is shut it off
wayne
« Reply #5 on: August 19, 2020, 09:50:24 AM »
 I think a mustang gt and crown vic cop car have a restricted heater hose to help the save the core.At least my 84 mustang did a friend of mine that worked at a ford dealer told me about it.Just a rubber part that slips in heater hose with a smaller hole in it  most dont know its their and throw it out with the hose.
fairlaniac
« Reply #6 on: August 19, 2020, 08:53:18 PM »
Thank you for some excellent options. I appreciate it.
Doug Bender
1978 F150 2WD 390
