Author Topic: Bullocks Power Service 461 FE, TFS Heads, RPM, pump gas, 558 HP / 594 TQ  (Read 4854 times)
Performance Summary:
      Cubic Inches:    461    Dyno brand:  Stuska
      Power Adder:               Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:   558 HP @ 5750 RPM      Peak Torque:   594 @ 4000 RPM
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Ford CX-scratch CJ 428,  4.155 bore, squared, deck plate honed, 10.155 deck
   Crankshaft brand, cast or forged, stroke, journal size:  SCAT cast 4.25 stroke
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT I-beam, 6.70"
   Piston brand, material 4032 forged Autotec, 17.5cc full dish w/ symmetrical valve reliefs, SCR 10.55:1, .005 above deck, .046 quench
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  TRW mains, Clevite rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Mahle, standard tension 1.5mm/1.5mm/3.0 mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton 15-811 pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Canton 15-810 T-pan, no tray, factory Ford 90 degree oil filter adapter
   Oil and filter: 10w30 Penngrade with FL1A
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Oregon Cams hydraulic roller ground to requested specs , 233/241 @ .050", 113 LSA, 106.5 ICL, .600/.600
  Lifters brand, type:  Morel standard travel
  Timing chain and timing cover:  Cloyes billet, factory Ford cover
  Cylinder heads brand, material, port and chamber information:  Trick Flow, aluminum, 169.8cc port volume, 69.5cc chamber volume
  Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):  (used flow data info from Brent Lykins 396 FE build did not flow these heads)
      Intake               Exhaust
      .100  96             .100  66
      .200  159           .200  120
      .300  233           .300  164
      .400  283           .400  197
      .500  317           .500  215
      .600  333           .600  220
   Flow bench used, location:  Superflow SF600, Dale Meers Racing Engines
   Intake valve brand, head size, stem size:  Ferrea, 2.190", 11/32"
   Exhaust valve brand, head size, stem size:  Ferrea, 1.625", 11/32"
   Valve springs brand, part number, specs: PAC 1.55 as delivered in TFS assembly
   Retainers and locks brand, part number, specs:  TFS standard issue steel
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins non adjustable rollers
   Rocker shafts and stands, brand, material: Precision Oil Pumps hardened shafts, middle and end stands and studs, cut for rocker pattern
   Pushrods brand, type, length:  Trend custom
   Valve covers, brand, type:  Tony Branda repop chrome pentroof
   Distributor brand, advance curve information:  Pertronix billet, 14 initial, 18 mechanical, will have 6AL in car
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Tuff Stuff Aluminum
   Intake manifold brand, material, porting information:  Edelbrock RPM intake, plenum roof work, port squaring and equalization (not matched to head ports)
   Carburetor(s) brand, type:  SP Carburetors 780 vacuum secondary with choke and choke tower, no spacers, 1/4 insulating gasket
   Exhaust manifolds or headers brand, type: Dyno headers
« Last Edit: March 27, 2023, 03:21:22 PM by My427stang »
