Author Topic: Group buy-in on custom Scat forged cranks....  (Read 18445 times)
bluef100fe
Re: Group buy-in on custom Scat forged cranks....
« Reply #15 on: September 01, 2020, 09:06:09 PM »
Ah shoot I could’ve used one of those also, oh well. Maybe next time..
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #16 on: September 02, 2020, 03:53:26 AM »
If you’re interested let me know, I’ll see if they will let me add more right now.
« Reply #17 on: September 02, 2020, 05:48:06 AM »
Are these the F-43 lightweight series?
« Reply #18 on: September 02, 2020, 08:57:49 AM »
They are lightweight, but not the F43 series.   That series is typically only available for small block, shorter stroke stuff.
« Reply #19 on: September 23, 2020, 03:25:06 PM »
Scat says they are finishing up the cranks right now.  Shouldn't be too much longer.
« Reply #20 on: September 29, 2020, 02:37:23 PM »
Received my Scat crankshaft today, and survived the handling Ok.  Thanks for the chance at the buy-in.  Joe-JDC
Gaugster
« Reply #21 on: September 29, 2020, 06:15:21 PM »
My crankshaft arrived today also. Box was a little beat up but no damage that I can see. A quick caliper inspection shows that it's what I ordered. Working on a long term storage solution now. Looks like I need to suspend it by the rear flange and add more grease/oil for 1-2 years of storage.
Thx!
Update from 10/1/20 - Today my local UPS driver asked "how was my crankshaft"? I happened to be outside this morning and he stopped his truck on the way out of the neighborhood to make sure everything was all good. Very nice of him. Car guys are still alive and well.
« Last Edit: October 01, 2020, 01:17:40 PM by Gaugster »
XR7
« Reply #22 on: September 29, 2020, 09:36:23 PM »
I am curious what these cranks weigh. Can one or more of you weigh them on a semi accurate scale? Some of the newer bathroom scales are pretty good. I have weighed several cranks and just want to see where these fall in. On the box label on the part number, does it end with -2 or -3, or something else? Did most get 4.375 stroke or did anyone get a 4.125 or 4.0 or 3.78??? It seems 4.25 is the most popular but sometimes it is fun to be different when given a choice. Thanks.
Gaugster
« Reply #23 on: September 29, 2020, 10:08:53 PM »
Sure. The 4.375" stroke crank measures 65.2 LBS including the box and packing materials. (Cardboard, foam, paper) I used my bathroom scale. Weight will change a lot based on the applications bob weight & balancing procedure.
My part number is 7-427-4375-PCG-33
7 = Custom Forged
427 = FE
4375 = 4.375"
PCG = PRO COMP (G = Gun Drilled Mains?)
33 = 2.200", 2.008", 6.7" (Rod journal and rod length)
« Last Edit: September 29, 2020, 10:38:56 PM by Gaugster »
XR7
« Reply #24 on: September 30, 2020, 07:51:25 PM »
7 = Custom Forged
427 = FE
4375 = 4.375"
Thanks for the info, but you are cheating LOL (just kidding). You need to take it out of the box and have a good look see anyway... then you can weigh the actual crank, not crated shipping weight, you know you want to take it out of the wrapper.
« Reply #25 on: September 30, 2020, 09:14:27 PM »
I don't have an accurate bathroom scale, mine started reading 10# high for some reason.  Here is the sheet that came with my Scat crankshaft yesterday.  Joe-JDC
« Reply #26 on: October 01, 2020, 06:34:24 AM »
Everyone got 4.375" this time around, but we can do any configuration between 3.780" and 4.375".  I've done these in 3.980", 3.780", etc., but you can make it whatever you want.  I've also done them with 2.100" journals, but when you get below the BBC journal,  the rods start getting real expensive.
« Reply #27 on: October 01, 2020, 07:34:10 AM »
7 = Custom Forged
427 = FE
4375 = 4.375"
If someone doesn't before Saturday I will weigh the one I boughy.  However, it's a carboard box with styrofoam and cardboard end caps, wrapped in paper.  Can't weigh much, and it's certainly noticeably lighter than the cast 4.25 ones I have
Gaugster
« Reply #28 on: October 01, 2020, 08:30:27 AM »
7 = Custom Forged
427 = FE
4375 = 4.375"
That's part of the reason why I detailed what the packaging was. So probably 65lbs for the raw crank as it wasn't bolted to a block of wood or anything substantial. Not sure my bathroom scale would survive with ~65lbs and the small surface area of the rear flange alone.
Gaugster
« Reply #29 on: October 01, 2020, 08:31:43 AM »
My scale did the same thing but it's because of beer and whiskey. :)
