Author Topic: windage tray  (Read 28902 times)
Re: windage tray
« Reply #60 on: August 14, 2020, 01:09:03 PM »
Yeah, many times in a heads up, a record attempt, or trying to move up the qualifying sheet, not unusual for a Stock Eliminator racer to drop some oil, or put in some super light oil, to pick up some performance. That said that "freed up" HP goes away pretty quickly once the bearings get starved for oil. If you could keep the oil several inches away the the spinning crankshaft, you would certainly greatly reduce windage and free up some power, but other than a jacked up 4x4 truck, a oil pan with a 12" + deep sump dragging on the ground just ain`t very practical. When I tried running low oil level in my 85 Mustang Stockers 302, it certainly ran a bit quicker and faster, but with the rear sump pan, even moderate braking caused the oil pressure gauge to drop an uncomfortable amount. Same with superlight oil, I ran some Royal Purple Racing 11 oil, about 0W15. It poured like water, even cold, but even though it only lost a bit of oil pressure, I just didn`t  feel comfortable leaving that oil in more than a few passes.
HR427
Re: windage tray
« Reply #61 on: June 07, 2021, 07:25:09 PM »
Anyone try this setup from crankscrapers.com?
Re: windage tray
« Reply #62 on: June 07, 2021, 08:34:17 PM »
I used one of their standard scrapers and a Canton screen tray. I had to do some minor clearancing to fit with the crank and rods how I wanted and elongate some of the pan rail bolt holes so it would line up. I also removed the "mini scraper" from the Canton tray. Whether it does anything or not, I don't know. I'm telling myself it does to justify the purchase.  ::)
390rpm
Re: windage tray
« Reply #63 on: June 17, 2021, 02:37:01 AM »
This link may give someone some ideas. It would be cool to try if you wanted to see everything moving.
 https://www.youtube.com/watch?v=gxw3rLFlsTc
Re: windage tray
« Reply #64 on: June 17, 2021, 05:51:20 AM »
After I quit chuckling the pan was kinda interesting.
The oil aerated much quicker than I thought it would in this particular set up.
390rpm
Re: windage tray
« Reply #65 on: June 17, 2021, 01:51:55 PM »
Hahaha, leave it to the Russians. I think they were running it a little too low initially.
