Author Topic: Back up 391 steel crank  (Read 7011 times)
mike7570
« on: August 10, 2020, 05:27:22 PM »
For sale 391 steel crank - SoCal area $850 + shipping
Recently finished machined and nitride for FE use by Castillo's in La Mirada, CA.
Stroke 3.99,  Rod Journal BBC std. 1.90 width, mains -.010.
Reason for sale - I found out that the balance cost was going to be excessive using a NHRA mandated rotating assembly weight for a stock eliminator 428. The bob weight was 2207.
The crank will balance at a much lower cost using light weight rods & pistons (I do not have an estimated cost for that, it's up to you)
« Last Edit: August 20, 2020, 12:04:15 PM by mike7570 »
mike7570
Re: Back up 391 steel crank
« Reply #1 on: August 20, 2020, 12:09:41 PM »
for sale again.
wcbrowning
« Reply #2 on: August 20, 2020, 06:13:59 PM »
Was the crank snout turned down to standard FE dimensions?
mike7570
« Reply #3 on: August 20, 2020, 11:35:35 PM »
Yes, 1.375 diameter
cwhitney67
« Reply #4 on: August 27, 2020, 07:54:42 PM »
Mike you should keep the crankshaft and use it. NHRA never looks at the balance.
bluef100fe
« Reply #5 on: September 04, 2020, 05:32:35 AM »
If a guy had a 4.350 bore block with that crank would be a lot of fun for a open stock pulling truck with a set of high riser heads... and a 1030 three barrel carb..
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
BigBlueIron
« Reply #6 on: September 04, 2020, 09:00:51 AM »
Word!
bluef100fe
« Reply #7 on: September 05, 2020, 05:47:08 AM »
I just need a big bore block lol
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #8 on: September 27, 2020, 03:28:34 PM »
I thought Stock Eliminator had to use factory rods or only certain part numbers of aftermarket rods that have stock length and journal size. Has that changed?
« Reply #9 on: September 27, 2020, 03:42:05 PM »
There are specific NHRA “accepted” rods that have the BBC rod journal size.
mike7570
« Reply #10 on: September 27, 2020, 11:52:48 PM »
There are numerous rods available for factory journal cranks but only one crower rod for the BBC dimensions. There is a minimum weight for the piston and rod assembly that also needs to be maintained and that’s why my 391 crank is for sale. If I put the balancing cost toward a new Scat crank and sell the steel 391 I actually save money. If I don’t sell it I figure I can keep it and use it for playing outside of stock eliminator. Maybe something with Jays new heads.
« Last Edit: June 22, 2021, 06:16:58 PM by mike7570 »
mike7570
« Reply #11 on: June 22, 2021, 06:17:46 PM »
Crank still for sale, inflation has not affected the price, yet :)
