Author Topic: To Sleeve , or NOT to sleeve , the age old question.  (Read 13582 times)
Re: To Sleeve , or NOT to sleeve , the age old question.
« Reply #15 on: June 04, 2024, 07:39:52 AM »
I wouldn't risk sleeving all the bores, you are still likely to weaken the top and have cracks up there after running.  Just sleeve the non-adjacent bores.  Also, for what it's worth, I had a .060" over 406 block that went to .080" over with no problems.  Some of those old blocks were really thick.  I wouldn't hesitate to bore it bigger if you have a sonic check done and you weren't going to put more than about 500 HP through it.
MeanGene
« Reply #16 on: June 04, 2024, 08:35:59 AM »
I have a sideoiler block that our old friend Hollis Franks was ready to take to the steel mill as he was pissed at it. He had spent a lot on it, lifter bores are bushed, and it has thick sleeves in all 8- too thick in my opinion. Bored into water, and decks compromised. It ran fine, but soon blew bubbles. He bought a std block from me, and brought the old one along "look at this!". Hate to give up on it, otherwise nice block. My buddy has a 672 ci 460 in his Pro Modified pulling truck, which has 1" thick deck plates and then sleeves- gotta admit, 460's are easier, just not as cool lol
427John
« Reply #17 on: June 04, 2024, 03:18:03 PM »
So is the weakness from the width of deck surface between the bores which would be ~ the same as a std 427 or is it due to the overbore making the transition from top of cylinder to bottom of deck surface too thin? I was reading something elsewhere that made it sound as if it was the distance between bore edges but maybe I was misunderstanding it.
« Reply #18 on: June 04, 2024, 08:31:03 PM »
427s have a different shape to the outside of the bore casting, which makes them stronger.  Kind of looks like a cloverleaf in cross section.  Makes them quite a bit stronger.  Your 406 doesn't have that shape, so if you bored it to a standard 427 bore size, it wouldn't be as strong as a 427 block.
« Reply #19 on: June 21, 2024, 09:45:10 AM »
Based on local prices here - and the complete lack of performance auto machine shops except for one maybe two - unless the block is a high value & rare piece, it's not economical to sleeve anything. The sleeve isn't the cost, it's the other setups and machine work that is 4~5 times the cost of just the part.  I'm a 351C guy and I'm slowly switching to 351W base blocks and aftermarket only. The stockers can't take the abuse and it's completely uneconomical now to fully prep an 50+ year old block.
