Author Topic: Cooling upgrade has arrived <update> road test  (Read 7821 times)
AlanCasida
« on: July 10, 2020, 05:57:13 PM »
I decided to take out the small, thick engine driven fan arrangement I have in my '65 Mustang in favor of a bigger, thinner, dual electric fan setup. Hopefully this will be an improvement over my current setup. Now I just have notch my frame and set it in.  :o
« Last Edit: July 22, 2020, 04:39:57 PM by AlanCasida »
Dan859
Re: Cooling upgrade has arrived
« Reply #1 on: July 11, 2020, 08:04:17 PM »
That looks nice!  Are the fans and shroud some sort of kit?  I'd like to do something similar on my Comet.
Take care,
Dan
AlanCasida
« Reply #2 on: July 11, 2020, 08:53:33 PM »
Take care,
Dan
Yes the fans and shroud came together. The fans are 12" Spal and are rated at 1670 cfm each. I got it off of Ebay and it was about $100 less than similar components from a parts warehouse.
AlanCasida
« Reply #3 on: July 22, 2020, 04:30:04 PM »
Well I took the Mustang out today to see if my upgrades made any difference and it seemed to be working ok. It was about 95 here with a heat index of 102. Going down the highway it stayed around 190 and the same in town. That is until my overdrive quit working so I got to torture it the last 25 miles running 3000 rpm at about 55 mph. Then it got up to about 205-210 but when I got home I let it set idling for about 5 minutes and the temp went back doe to 190 before I shut it off.  So the radiator/fan set up is working ok but it is still an oven in the car. I am not sure I am going to want to spend 6+ hours in it for DW or RMRW. :(  When I built the headers I wanted them tucked up fairly close to the underbody because I don't like headers hanging way down under the car. This may have been a mistake. Even after just 60 miles my feet were burning up.
« Last Edit: July 22, 2020, 04:40:26 PM by AlanCasida »
RustyCrankshaft
Re: Cooling upgrade has arrived <update> road test
« Reply #4 on: July 22, 2020, 06:13:28 PM »
Sounds like it's time for some insulation on the floor above the headers. DEI and HeatShield products both have some good stuff I've used - makes a noticeable difference. Combine it with some under carpet insulation and it can make a big difference.
At least the engine is cool and happy, even if the driver isn't quite so comfortable!
AlanCasida
« Reply #5 on: July 22, 2020, 07:24:49 PM »
I've already put 1/2" of heat absorbent mat under my carpet, which still has the jute backing on it. I also put 1/2" of heat absorbing mat on the firewall behind the OEM style insulator. When I was checking the floor when I got home I put my hand on the front roll cage down bar near the floor and it was really hot too.  If I open the floor vent it's like turning the heater on because it blows the heat from the floor up in my face. Maybe I am just getting old...:)
70tp
« Reply #6 on: July 22, 2020, 08:57:14 PM »
I’ve got a 458 tunnelport in my 70 Mach - here , in fl, we used to joke that our shoes were melting to the floor.    Always was torture to drive it in the summer    I could make the motor run cool, but the interior was another story.   I want to try to install ac in it bit I’m not sure it can overcome the interior heat
« Reply #7 on: July 22, 2020, 09:48:52 PM »
Alan, are your headers ceramic coated?  That coating really cuts down on the radiant heat...
AlanCasida
« Reply #8 on: July 22, 2020, 10:07:49 PM »
They are coated but not like Jet Hot. I got it done locally and I'll just say I was less than satisfied. That may be what I need to try.
winr1
« Reply #9 on: July 22, 2020, 11:27:33 PM »
Is there any way to allow incoming air to flow through the engine bay and to the outside ??
That is I mean, air other than the air that has went through your radiator
Some sort of ducting such as disk brake backing plates or such ...
Ricky.
wcbrowning
« Reply #10 on: July 24, 2020, 11:43:38 AM »
How about header wrap?
cobracammer
« Reply #11 on: July 28, 2020, 07:16:32 AM »
I had this exact same issue!  It was opposite of what I thought, but by mounting the fans directly on the radiator without the shroud, I got more airflow at any speed and the temp came down.  My only difference between overheating and perfection was removing the shroud. Hope this helps   ;)
Jason
« Reply #12 on: July 30, 2020, 11:42:34 AM »
Maybe a thin aluminum heat shield underneath between the Body and Header like how new cars have ? Maybe some heat wrap in that area ? Jet hot Coating ? maybe a combination of several things Jet Hot and a heat shield or wrap ?
« Reply #13 on: July 30, 2020, 01:21:40 PM »
Yep, my Jet-Hot coated Hookers made an amazing difference in underhood heat. Need to ask though: total timing is ? Running a vacuum advance?
« Last Edit: July 30, 2020, 01:23:37 PM by machoneman »
AlanCasida
« Reply #14 on: July 30, 2020, 03:44:07 PM »
[/quote
My total timing is set at 32 deg and I do not have vacuum advance. The engine seems to be running ok as far as temp goes. I guess  having always run in a big car (66 Galaxie) I am not used to the extra interior heat that goes with a big motor in a small car.
