Author Topic: Intro and current project  (Read 138076 times)
Re: Intro and current project
« Reply #180 on: October 04, 2015, 09:02:35 AM »
I wonder if those shocks work in a similar fashion to Competition Engineering's slide-a-link traction bar setup?  If so, you have hit on a really good alternative.  Are the shocks adjustable?
« Reply #181 on: October 04, 2015, 11:25:32 AM »
These are not but that is a good idea to really tune it up. ;)
fastback 427
« Reply #182 on: October 04, 2015, 04:15:25 PM »
Very cool idea!!! Maybe another burn out / hole shot video is in order. Just for posterity  ;)
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Bolted to Floor
« Reply #183 on: October 04, 2015, 05:27:32 PM »
I second that!!
« Reply #184 on: November 25, 2015, 12:10:29 PM »
Since it's a slow day on the forum and I have the day off I'll tell you my tale of wo'.
I'm going to chalk this one up to a learning experience with the words of Blair Patrick ringing loud and clear in my head.
Was driving to work the other day in my '74, cruising along the freeway on a Sunday with no traffic. Had the radio off just listening to engine music at 2500 rpm with no load.
All of the sudden nothing .............. then bang, bang, bang backfires. You should have seen the scramble of cars trying to get on, off, up, down or anywhere on the freeway (mind you this was a few days after Paris). Pushed the clutch in and shut it off and was trying to roll off to the side of the freeway with a couple of these morons blocking me as they were trying to pull off also for some reason.
Anyway, made it to the shoulder in a nice wide area.
I had recently lost a Mallory ignition box in my '61 F100 and figured this would be about the same deal. Either a coil or the 6AL.
I turned it over a couple times and figured out it was terminal so called for a tow.
When I got a chance to work on it I did all the spark tests and SOB, I had spark!
This is when the words of BP started to creep into my brain.
"After about 10,000 miles you'll find yourself on the side of the road". Crap, I still haven't changed to a steel dizzy gear, the bronze is still there.
I had checked it before and I know Kevin McCullough is getting mileage on them so I figured I was doing ok.
Wrong, wrong, wrong. Go to the back of the line and start again.
Pulled the dizz and yup, the bronze gear was sheared.
So I changed the oil and filter. I strained the oil through a rag into a five gallon can and got NO pieces.
Then I cut the filter open and again found no pieces.
I then poured about a half a gallon of oil down the dizzy hole to try and wash anything out and again got nothing.
There's got to be some pieces in there somewhere. I didn't check the oil in the filter when I poured it out.
I got about 17,000 miles on the gear.
Hey Kevin, just a heads up ;)
Here's a couple shots of what it looks like.
« Last Edit: November 25, 2015, 12:22:31 PM by turbohunter »
« Reply #185 on: November 25, 2015, 04:17:42 PM »
Ouch!  Don't feel bad Marc, I've done that to one myself, although that was quite a while back.  I wouldn't worry too much about the shavings in the engine, that gear material is soft and probably came off in very small pieces.  The filter should have caught it, and I doubt it did any significant damage to the oil pump.
As you now know, steel gears are your friend.  Thing is, though, there are a few people out there who have run those bronze gears forever; Wes Adams comes to mind.  I don't know how they do it.  I suppose it boils down to how much force is on the gear, and that is probably determined by the oil pump and the oil...
« Reply #186 on: November 25, 2015, 04:36:06 PM »
Aaaaah that's a good thought about the pump.
I've got a high volume pump on it.
Very interesting thanks.
I don't feel bad. But I'm learning a heck of a lot.
« Reply #187 on: November 26, 2015, 11:33:26 AM »
You never really know if it went into the pump, but likely you will be OK.  I will say, if able to drop the pan, I'd probably do it, but odds are way in your favor that it'll be fine.
Be sure you put that new steel gear at the right depth, otherwise it will likely shear a pin.
BTW, you did good on that gear, I rarely see them last that long.  I avoid them now, steel is the way to go when you need a special gear.
