Author Topic: Jog my memory - Erson Adjusters  (Read 4431 times)
DuckRyder
« on: June 21, 2020, 06:50:07 AM »
So on build number 1 I had issues with pushrods and adjusters.
Smith Brothers suggested an increased size ball and cup. Once again I can no longer read the invoice.
What would have been the typical upgrade there 10-15 years ago?
Related question:
Any one make an adjuster with a smaller nut (a lower profile adjuster)?
Robert
hbstang
Re: Jog my memory - Erson Adjusters
« Reply #1 on: June 21, 2020, 11:48:55 AM »
you can get the harland sharp adjusters and smaller nuts on there website.i think they all use a 5/16 cup size.or the fe with a 3/8 ball.not cheap parts.they are quality parts.http://www.harlandsharp.com/component.htm
DuckRyder
« Reply #2 on: June 21, 2020, 05:40:59 PM »
Thanks,
Guess I better get the tools out and measure.
Those do look nice if I can determine the ball size I need.
R
Robert
rockhouse66
« Reply #3 on: June 21, 2020, 07:24:01 PM »
Maybe I don't understand the question but I just looked up the HS rockers to confirm the ball size and found it to be 3/8".
Jim
DuckRyder
« Reply #4 on: June 22, 2020, 06:00:22 AM »
My original person adjusters failed.
My recollection is that Smith Brothers talked me into upsizing the balls because i was replacing the pushrods too.
So i guess the question is are the original Erson adjusters smaller than 3/8 or are mine larger... (alternately am i remembering wrong and there is no issue at all)
Robert
« Reply #5 on: June 22, 2020, 07:05:09 AM »
Aside from length differences in specific builds, I think the Ersons just use stock cup ends.  I certainly haven't used anything else on my two sets
DuckRyder
« Reply #6 on: June 22, 2020, 03:45:48 PM »
Got it figured out.
They are 3/16 radius, which = 3/8 diameter ball ...
Quote from: pushrods.net
5/32" Radius = 5/16" Diameter
3/16" Radius = 3/8" Diameter
9/64" Radius = 9/32" Diameter
Robert
DuckRyder
« Reply #7 on: July 05, 2020, 08:06:37 PM »
The Harland Sharp adjusters work perfectly.
Robert
« Reply #8 on: July 05, 2020, 08:23:49 PM »
I used the Harland Sharp adjusters in my Erson's because they are a little more precise. The HS ball is the closest to .375". The Crane and Erson are a little smaller and you can even feel it moving the adjuster in a pushrod end by hand.
