Author Topic: Guess the horsepower game 6.20.20 #2  (Read 20161 times)
Twinibeam66
Re: Guess the horsepower game 6.20.20 #2
« Reply #15 on: June 22, 2020, 08:26:24 AM »
A lot going on with this build, cant wait to see what it makes ?
My Guess is- 608 HP
BigBlueIron
« Reply #16 on: June 22, 2020, 09:37:01 AM »
625
Riderjeff
« Reply #17 on: June 22, 2020, 09:58:20 AM »
That’s going to be a crazy cool ride!
697 HP
chilly460
« Reply #18 on: June 22, 2020, 10:02:49 AM »
651hp
6667fan
  • Every Second Counts
« Reply #19 on: June 22, 2020, 11:03:45 AM »
Hey Brent, looks like some burly push rods there. Are they a must have considering the rest of that valve train? I’m asking because I have seen you use lighter stuff. Is that ride going to have an aluminum flywheel?
656 peak hp.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
338Raptor
« Reply #20 on: June 22, 2020, 11:48:16 AM »
627
« Reply #21 on: June 22, 2020, 11:50:38 AM »
656 peak hp.
JB
Jim, I always use the biggest pushrods I can fit.  A .135" wall 3/8" pushrod is the minimum that I would use here with these spring pressures.  If I could have made a 7/16" pushrod fit, I would have used them.
mike7570
« Reply #22 on: June 22, 2020, 03:18:16 PM »
Port the heads! 750hp. Okay not ported
705 @ 7500
« Reply #23 on: June 22, 2020, 04:59:38 PM »
705 @ 7500
It would be something to try on a future engine, but I haven't really found where they need any port work so far.  I think it would take a 480-ish cube engine or a lot higher rpms to need more volume out of them.
They usually come in just a hair under 170cc and flow about 330 cfm.  They're good pieces and will feed a 465 inch engine up to about 700 hp at 7200-7500 rpm.
« Reply #24 on: July 16, 2020, 05:26:47 AM »
Still a week or two away on this one.   The room constraints have really proved to be a pain in the booty, as far as pump placement, belt length, hose routing, etc.
Finally got everything plumbed the other day and was able to prime the dry sump pump.  I always prime the pump with the engine on the stand and the intake off for a reason.....and this is one of those reasons....  Sometimes a solid roller lifter won't pass enough oil to the rockers and the lifters need a connecting groove in order to get adequate flow.
In this picture, the rockers on the left side of the photo are still dry after a couple minutes of priming.  A quick groove and they pass oil like they should.
Jb427
« Reply #25 on: July 16, 2020, 09:51:06 AM »
Love it Brent
what do you use to grove the lifters?
My build is very close to the same as this apart from the dry sump.
the T&D race set up i'm using a MT style cast tappet cover any clearance problems with tappet cover's?
Twinibeam66
« Reply #26 on: July 16, 2020, 09:56:27 AM »
722 HP
WerbyFord
« Reply #27 on: July 16, 2020, 11:03:58 AM »
Just found this today too.
Cats are asleep, one recovering from a wound, so a little Gonkulator time.
JDC must have read the Gonkulators mind on this one.
With the engine driving the water pump and the fancy vacuum oil system in place, and your 2" dyno header setup:
Torq 607 at 4900
Powr 718 at 6800
That is one serious engine.
« Reply #28 on: July 16, 2020, 11:10:16 AM »
Love it Brent
I use a Dremel with a cut-off disc.
70bosscat
« Reply #29 on: July 16, 2020, 04:29:27 PM »
Nice piece. I say let 'er eat. 707hp
