Author Topic: Tell me how well this will work.....  (Read 13474 times)
« on: June 09, 2020, 02:50:55 PM »
This was done by one of our highly thought of crank grinders...
Luckily, it's the crank for my 352 project and not a customer's piece.  But still....
He ground it a couple of years back and I'm just now getting around to checking the balance on the crank.
Re: Tell me how well this will work.....
« Reply #1 on: June 09, 2020, 03:04:34 PM »
I think the question should be, "How long will this work??"
Holy stress-riser, Batman!  At least you'll be getting lots of earl to that rod  ;D
SMA390
« Reply #2 on: June 09, 2020, 03:06:05 PM »
Maybe that rod and piston will be faster
« Reply #3 on: June 09, 2020, 03:09:44 PM »
I have seen similar stuff before and I have pretty much hated it all the time.
Never caused a problem that I was aware of, but that oil crater gets really close to be exposed to the outside of the rod bearing - a major no-no
mike7570
« Reply #4 on: June 09, 2020, 03:11:06 PM »
Those aluminum rods fit a Honda journal?
here's mine with a 2.20
« Last Edit: June 09, 2020, 03:14:21 PM by mike7570 »
« Reply #5 on: June 09, 2020, 03:11:14 PM »
That's the second crank that I've had issues with from this guy.  Last time, I paid $1400 to have a 391 crank ground down and then had to have it ground again locally because the thrust surface had .004" of run-out.
As George Bush would say....
"Fool me once, shame on — shame on you. Fool me — you can't get fooled again.”
I know he saw it because he chamfered the hole.....
« Last Edit: June 09, 2020, 03:13:10 PM by blykins »
« Reply #6 on: June 09, 2020, 03:11:47 PM »
here's mine
No sir, they are BBC rods.
mike7570
« Reply #7 on: June 09, 2020, 03:16:24 PM »
My 391 above was done for $700.00 (plus a discount for the long wait)
« Reply #8 on: June 09, 2020, 03:17:31 PM »
Anyone got a 361 crank they wanna sell?
mike7570
« Reply #9 on: June 09, 2020, 03:24:19 PM »
Were you changing the stroke and he offset it incorrectly?
« Last Edit: June 09, 2020, 03:27:50 PM by mike7570 »
68fecyclone
« Reply #10 on: June 09, 2020, 03:27:42 PM »
   I have one, its been turned .020 on mains and rods I think. Never been used since it was turned. Still in a bag and just collecting dust. I'll sell it for a decent price plus shipping. Its in billings mt. Rob
« Reply #11 on: June 09, 2020, 03:30:27 PM »
No sir, just going to BBC journals.  It happens but it would have been nice if he had stopped when he saw that so I could have cut my losses.  It was sent to me ready to roll.
GerryP
« Reply #12 on: June 09, 2020, 03:59:57 PM »
It looks like it has nice radii.  But for that one funky hole.  Why not weld the crank?  Too much investment?
pbf777
« Reply #13 on: June 09, 2020, 04:02:30 PM »
      I don't think it's fair to blame the crankshaft grinder here, assuming that the grinding operation was not out of index, but rather solely the result the journal diameter reduction for the 2.200" diameter; adding stroke in the process changes the outcome some, but this observance is due to where Ford Motor Co. placed the oil drilling.  The only appropriate statement would be oh-well, it-is-what-it-is!
      And not intending to make excuses for the operator, but generally one grinds the mains first, then the rod journals, and perhaps this was a latter position in the grinding operation, and even when in the grinding process sometimes visibility is not so good until stopped at which point, well it-is-what-it-is; and hopefully the person contracting for the nonstandard operation is aware of the possible shortcomings of the modification, and that person must decide the usability of their creation, not the contracted machine operator, although that person may be willing to supply previous observations and opinions, particularly if inquired upon, it's not fair to make this result that persons' fault.
      But yes, with the proximity of this oil hole breaching the surface so near the journal radius, it would not be considered "ideal".          ;)
      Scott.
gt350hr
« Reply #14 on: June 09, 2020, 04:16:26 PM »
      Worthless to weld. The weld will actually cause it to break sooner by the stress cracks from the welding process.
