Author Topic: Parts washer solvent?  (Read 5684 times)
chilly460
« on: May 29, 2020, 01:12:49 AM »
Digging into an engine project and will need a LOT of parts washing.  I have a parts washer I’ve actually never used, mostly because I can’t decide what solvent to use.  I’m not too keen on running mineral spirits as I’m in a tight space and do a lot of grinding near the washer, is there any non-flammable fluid that actually works?
Re: Parts washer solvent?
« Reply #1 on: May 29, 2020, 05:35:21 AM »
I actually use a Summit Racing brand of fluid.  It's some kind of green "smart" fluid.  Its a very good solvent, non-flammable, doesn't stink, doesn't burn your hands.
cattleFEeder
« Reply #2 on: May 29, 2020, 06:44:58 AM »
« Last Edit: May 29, 2020, 06:51:42 AM by cattleFEeder »
Remember, RPM is your friend
hwoods
« Reply #3 on: May 29, 2020, 07:05:16 AM »
PSC 1000 solvent.  I buy at Tractor Supply high flash point 141 degrees if I remember corrrectly   $39.95 for 5 gallons
chilly460
« Reply #4 on: May 29, 2020, 10:53:50 AM »
Thanks, will check both out
« Reply #5 on: May 29, 2020, 01:12:13 PM »
The old standard, automotive cleaning solvent, is call Stoddard solvent. It's available at any petroleum supply company.
PSC 1000 solvent, is probably Stoddard solvent, with it's higher flash point. Stoddard works well but, the fumes can get to you if you use it where there no air current or if you use a air gun to spray it. I had to breath a lot of it, when I was a mechanic. Not good. Also, with extended use, it effects your skin. It will make your skin tingle and itch. Prolonged use, will result in your skin peeling, too. So, rubber gloves would be good.
What I use now, is a industrial, water soluble cleaner. to be mixed 10/1, as max strength but, I use it straight, like carb cleaner. It will take off 40 year old  slug and leave a clean surface but, doesn't remove the paint like carb cleaner and is very safe to use. I buy it for $22 per 5 gal or $5 per gal. I got 1 gal first to try it out. It worked so well, I went back and got the 5 gal bucket.
Gregwill16
« Reply #6 on: May 29, 2020, 02:08:10 PM »
Frank do you have a link where we can view this stuff?
« Reply #7 on: May 29, 2020, 03:36:43 PM »
Same - works, no smell.  Last price I paid here was $50/5 gallons.
« Reply #8 on: May 30, 2020, 02:39:09 AM »
It is a generic brand and maybe only available in my area. I looked for it online and couldn't find it.
I'll take a picture of the label, on the bucket, tomorrow.
It's a industrial grease remover so, it should be widely available, on different brand names.
« Last Edit: May 30, 2020, 04:49:51 PM by frnkeore »
« Reply #9 on: May 30, 2020, 04:55:30 PM »
Ok, this is what it looks like and the ingredients in it.
The valve cover came from a std bore, D0 302 heads and looked pretty bad before I put it in the cleaner.
Royce
« Reply #10 on: May 31, 2020, 09:14:42 AM »
Looks like a product from the food industry??  Definitely not available here in the Midwest.. I might try the Summit product.. Tired of Lacquer thinner and gasoline as cleaning agents.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #11 on: May 31, 2020, 12:01:32 PM »
Yes, I got it at a "open to the public" whole sale supplier, that caters to restaurant type businesses.
RustyCrankshaft
« Reply #12 on: June 01, 2020, 05:25:55 PM »
First Street is house brand from a restaurant supply chain Cash and Carry, now called smart food. They are open to the public and they actually have some good deals.
https://www.smartfoodservice.com/
That degreaser does work well for the price.
FirstEliminator
« Reply #13 on: June 02, 2020, 11:10:26 PM »
odorless mineral spirits
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
