Author Topic: Engine paint  (Read 8972 times)
T U Bar
Engine paint
« on: May 12, 2020, 09:13:13 AM »
I'm assuming I need to stick with the "old" Ford blue for a '66 block, but just wanted to confirm?  When was the transition to "Dark" Ford blue?
Recommendations for rattle can paint?  VHT?  Duplicolor?  Other?
Thanks!
Doug
‘66 Fairlane GT
Re: Engine paint
« Reply #1 on: May 12, 2020, 09:15:45 AM »
I prefer Duplicolor Old Ford Blue.
64PI
Re: Engine paint
« Reply #2 on: May 12, 2020, 09:26:28 AM »
I've always had good look with Duplicolor engine paint. Durable stuff. I can't speak for the color match on the blue. I always spray my blocks black.
Re: Engine paint
« Reply #3 on: May 12, 2020, 09:42:37 AM »
I use the Duplicolor ceramic engine paint as well.  The transition to "Dark Ford Blue" wasn't for several years later.
FElony
Re: Engine paint
« Reply #4 on: May 12, 2020, 09:45:41 AM »
Thet thar izza p q leer lookin fe hedd, iffen ah do say.
Do I get a cheezburgr for mentioning the part number is actually DE1621?
Does Color Place come in cans? I thought it was only house paint. Am I woefully mistaken?
475fetoploader
Re: Engine paint
« Reply #5 on: May 12, 2020, 08:46:01 PM »
Has anyone tried por15 engine paint? I’ve used their products for sealing inside doors and things of that nature for many years. I bought a quart can, it brushes and sprays nicely, but haven’t ran the engine yet to see how long it lives.
1967  519 c.i.  TKX 5 speed
CV355
Re: Engine paint
« Reply #6 on: May 13, 2020, 06:21:24 AM »
I have used the POR15 engine enamel a few times.  It self-levels nicely, brushes on well, lasts decently.  I always better luck spraying than brushing, though both work.  It doesn't need much reducer, if any.  It did seem to take longer to "bake" than other brands.
I have also used VHT and Duplicolor.  VHT seems to stain very easily.
« Last Edit: May 13, 2020, 06:22:59 AM by CV355 »
Re: Engine paint
« Reply #7 on: May 13, 2020, 07:54:30 AM »
Well, excuuuuuse me  ;D   Look again, you didn't see anything...
 Yes, Walmart paint comes in cans.  And happens to be decent paint, believe it or not.  That number may not be good anymore.  And just for fun - the place around here that has the best selection of Krylon paint is Hobby Lobby.  I found a metal flake purple that nearly matches the dragster color and can be used for touchups.  Only deal is that it has more and finer flake in the finish.
« Last Edit: May 13, 2020, 08:04:17 AM by Falcon67 »
FElony
Re: Engine paint
« Reply #8 on: May 13, 2020, 09:49:08 AM »
Nope, still says DL. I ain't falling for that Star Wars psych when a cheezburgr is at stake. Nosiree.
I'll check HL for Krylon. Planning to stop by AutoZone and O'Reilly's to see if they can order Duplicolor that is not normally on the shelf. Years ago I tried the first version of Metalcast in a couple different colors. Initially, the results were very nice, but they faded after a while. I see they have it again with supposedly a better adhesion promoter, so I might give them another shot.
GJCAT427
Re: Engine paint
« Reply #9 on: May 13, 2020, 04:24:09 PM »
I`ve been using Por 15 Black engine paint for yrs on all my 427s. It stays on the exhaust ports well. Wish I could find something that would stay on the long cast exhausts.
RustyCrankshaft
Re: Engine paint
« Reply #10 on: May 13, 2020, 06:28:31 PM »
It's expensive, but I've found that if you don't want the paint to burn off the manifolds or around the exhaust ports you can ceramic coat the inside of the manifolds and the exhaust ports in the head and that will keep a lot of the heat out of the material and keep a good hi-temp paint from baking off for a long time.
But it's expensive and a lot of messing around on the head to get the coating done well.
Re: Engine paint
« Reply #11 on: May 13, 2020, 10:54:42 PM »
I, too, believe a Ford performance engine should be black. ;)
Re: Engine paint
« Reply #12 on: May 14, 2020, 11:00:35 AM »
Clear your browser cache
Re: Engine paint
« Reply #13 on: May 14, 2020, 12:13:53 PM »
i use the old ford dark red from back in the y block days.its my favorite engine color. fooy on original,i like the red
FElony
Re: Engine paint
« Reply #14 on: May 14, 2020, 02:57:15 PM »
Dagnabbit. I guess there really is no free lunch. Back to begging on the off ramp.
