Author Topic: CCing heads  (Read 5646 times)
390 Cougar Conv
CCing heads
« on: January 21, 2013, 01:51:56 AM »
I recently bought a Burette. Thanks to Jay for telling where to get one. The directions tell me to mix alcohol and water 50/50. Witch one do I use, Alcohol. Denatured, Isopropyl or???
1969 Cougar XR7 GT 390 S Code C-6 Convertable
1965 Comet Caliente 302 C-4 Convertable
rockhouse66
Re: CCing heads
« Reply #1 on: January 21, 2013, 08:35:20 AM »
I use the colored windshield washer fluid.  Maybe I shouldn't?
Jim
Re: CCing heads
« Reply #2 on: January 21, 2013, 08:43:34 AM »
I think a lot of fluids, even water, would work if you have a good seal on the valves, but alcohol works well because it won't dissolve the grease that you use to seal the plexiglas plate to the deck of the cylinder head, and it won't rust anything if some of it remains.  I always use straight isopropyl alcohol, but a mix or windshield washer fluid would probably be fine.
Re: CCing heads
« Reply #3 on: January 21, 2013, 10:39:24 AM »
I use windshield washer fluid, cheap and works well.
fe66comet
Re: CCing heads
« Reply #4 on: January 21, 2013, 12:10:38 PM »
Windex here cleans the bench top too LOL.
