Author Topic: mechanical roller lifters on a hydraulic roller can  (Read 13963 times)
jspindle
« on: May 03, 2020, 02:14:33 PM »
I have a Crane Cans short travel hydraulic lifter (35532-16) failure at only 1,900 mile on the street. When I pulled the lifter it was collapsed. I poked at it until it came back up but it feels weak. I want to use solid roller lifter with the hydraulic roller cam. Thoughts?????
Here is what I have.
1966 Side Oiler FE 427 4.250 bore and 4.250 = 482 ci
Bear Block Heads 74cc with Mahle Pistons 930264550     10.6:1
Comp Cams 33-000-11 .669 intake lift .666 exhaust lift
                   adv. dur            303                303
                   dur.@.50            248               248 lobe sep 110.00
Comp Cam springs 26055-16 1.204" 155@1.925
                                                      435@1.275
Blue Thunder 2x4 w/ Quick Fuel matched 750 cfm
Crane cams lifters hydraulic rollers 35532-16 body dia. 874 follower wheel dia. .700 pushrod seat height 2.320
I did not measure the push rods. Hoping to find a lifter that will work with the one I have.
Anyone done this??   Thanks
Re: mechanical roller lifters on a hydraulic roller can
« Reply #1 on: May 03, 2020, 02:19:13 PM »
I think a solid roller will be more likely to fail.  A hyd lifter takes up lash, a solid won't, you can certainly tight lash, but if it was just a bad lifter, buy one or a pair.
That being said, if you do go hyd roller, I think Morel is the way to go
« Reply #2 on: May 03, 2020, 02:35:54 PM »
                   adv. dur            303                303
                                                      435@1.275
You're better off just replacing the pair.   When you do a solid roller on a hydraulic roller cam, the lash has to be set really tight hot.....like .004-.005".   In addition, I know that you just had a failure in 1900 miles, but solid roller lifters won't last forever.  As Ross says, they are subject to being pounded against the cam lobe because of lash and they will fail eventually.
Crane doesn't have bad lifters, they're just pricy.  I use Morel, but if I were in your spot, I would just throw a new pair of lifters and motor on.
With all of that being said, you have a lot more spring pressure than you need and I'm not sure what standard travel Crane lifters will hold effectively.  If your spring measurements are correct, your seat pressure is fine, but if your seat is at 1.925", your open pressure is *over* 435 lbs, my guess is around 450 lbs.
In reality, you need about 375-400 max with that cam.
CaptCobrajet
« Reply #3 on: May 03, 2020, 02:38:07 PM »
If you go solid roller, you'll need .008 to .010 cold lash, and probably a little more valve spring.  Maybe 30-40 more seat and 50 more open.  A tightly lashed solid roller at those pressures will run a long time.
Ross is correct that Morel are the best hydraulic rollers.  I use Crower on the solid rollers and Morel on the hydraulics.  There are several options from Morel.  Looks like you would want severe duty and limited travel.  Not much different from a solid, really.
Blair Patrick
jspindle
« Reply #4 on: May 03, 2020, 03:01:57 PM »
The spring pressure was suppose to match the cam. I bought the heads loaded. Could my high spring pressure have caused the failure of the lifter? Should I get new springs? Thanks
« Reply #5 on: May 03, 2020, 03:13:23 PM »
It's possible.  I don't know why you need that kind of open pressure with a hydraulic roller.
I know the standard travel Morels say recommended open pressure is around 380-400.   Typically, with cams similar to yours, I run about 375-400 and 160/400 spring pressures with the correct camshaft will easily get an FE up to 6500 rpm.
I don't use Crane lifters, so I'm not sure what they're capable of, but if you're approaching 450 lbs open, it's a possibility that you could be exceeding the capability of the lifters.
Generally with higher spring pressures, I'm using the Morel HLT's, which are geared for higher spring pressures.
« Reply #6 on: May 03, 2020, 03:23:59 PM »
Do you have a build sheet with the heads, is that what you're pulling the numbers from?  That spring in Comp's book shows 150 lbs at 1.925" and 410 lbs at 1.275".  I'm kinda confused because your specs say 435 @ 1.275", but 1.925 - .670 = 1.255", so you'd actually be higher than 435.
jspindle
« Reply #7 on: May 03, 2020, 05:12:51 PM »
Brent,
You are correct. These #s were from the builder. He gave me the Comp Cams part#s too. So I posted his #s, which dont match Comps. I am confused too but havent reached out to the builder yet. Do you have part#s for the best springs and Morel lifters I should use? Thanks for your help. John
« Reply #8 on: May 03, 2020, 05:18:38 PM »
I use 26120 springs and 5325 lifters but I would reach out to your builder first and discuss it all with him.
jspindle
« Reply #9 on: May 03, 2020, 05:30:34 PM »
Thank you.
CaptCobrajet
« Reply #10 on: May 03, 2020, 05:54:44 PM »
The 26120 spring won't work with you cam.  It is a .600 max lift spring, and your info above says .660+.  That is a pretty healthy lobe for a hydraulic roller.  I think you would have trouble with the 5325 standard Morel lifter when you put enough spring on it.  If the spring you have isn't into coil bind,  it is probably about the right pressure for the hydraulic roller cam that you have......just the wrong lifter.  Going solid requires a little more spring, to control things when lash is introduced.  If there ever was a good candidate to run a solid roller on the hydraulic cam, yours is it.......just my opinion.  I'll bow out now and let you guys figure it out, but the 26120 isn't your huckleberry.
Blair Patrick
« Reply #11 on: May 03, 2020, 06:17:23 PM »
Blair is right, the 26120 won't work with your lift.  Sorry about that, I wasn't putting 2 and 2 together because I never run over .620-.630" lift on a hydraulic roller.   The 26120 will work with .630" lift, but that's about all she wrote, as they're usually right at .050" from coil bind there.
I have run standard travel Morels with some PAC springs up to 430 lbs without issue, but have never used the Crane lifters, so can't say as to whether they will handle the load or not.
« Last Edit: May 03, 2020, 06:22:17 PM by blykins »
« Reply #12 on: May 04, 2020, 09:07:57 AM »
Looks like you have Comp's QNX lobes.  From looking at the intensity specifications in the lobe catalog, they are a little less aggressive than what I usually run.  The extra lift will affect that a little but I think you could get away with 150-160 lbs seat and 375-400 lbs open.  If the heads are not CNC ported, the peak hp rpm will not be high enough to really justify a lot of spring pressure.
I would double back with your builder about the cylinder head build specs and double check the spring pressures.  If need be, there may be another beehive or small dual spring that you could use.
I'm not really a solid roller lifter on a hydraulic roller cam kinda guy.  I've done it before when I have used "hybrid" lobes, but those lobes are designed to be used with either lifter style and the lash is adjusted appropriately.  There is usually more than one way to get to the end goal, but if you switch to solid roller lifters, you're looking at a lifter change and a spring change both (maybe even pushrods).  IMO, it's just easier to replace the lifter pair and maybe adjust the spring pressures if necessary.
« Last Edit: May 04, 2020, 09:11:40 AM by blykins »
« Reply #13 on: May 04, 2020, 01:42:02 PM »
What Brent said - mostly because I've already asked same question about a 351C.  If you do buy solid rollers, spend the $$$ and get pressure oiling types.  I run Howards in the 393 dragster engine and still working good after 3 years.  Most people I know use pressure feed solid rollers and have excellent reliability.  I'd not blink to run those in a street or street/strip application.  The less expensive solids rely on splash oiling - don't do that on a street engine.
Also, I run Howards hydro rollers in the 351C street/strip car.  They have been in there for several years without any problems.  They down side is that they clearly state that their limit is 6500 RPM.  I've tested that and it's dead on.  My air shifter is set at 6300.
« Reply #14 on: May 04, 2020, 07:21:25 PM »
I thought hydraulic lifter sideoiler blocks didn't come around till '68? Maybe I'm wrong, or maybe it started out as a marine or industrial engine, or was drilled for hydraulics? Just curious.
