Author Topic: Anti-ballooning plate?  (Read 5437 times)
« on: May 01, 2020, 03:01:38 PM »
Would you get an anti-ballooning plate on a torque convertor for a naturally aspirated 470 inch FE making about 570 ft/lbs of torque? The anti-ballooning plates are usually used on nitrous or blower cars, I think?
thanks,
paulie
« Last Edit: May 02, 2020, 09:03:53 PM by plovett »
Re: Anti-ballooning plate?
« Reply #1 on: May 01, 2020, 03:04:52 PM »
570 ft lbs is the equivalent of a small block with nitrous or blower :) just saying . seriously you need it
57 lima bean
« Reply #2 on: May 01, 2020, 03:24:38 PM »
     Had the same concerns with an increase of 150 FPT in my street engine.
        https://www.youtube.com/watch?v=6Qid0-GaW44&list=PLBXvzd5ICqLWa1pH3li6L6p_M6nrpka1R&index=7&t=0s
« Reply #3 on: May 01, 2020, 04:39:53 PM »
I think it also depends on if its a "foot brake" car, or will be launched at WOT with a transbrake. Either way, I see no downside to a torque convertor with an anti balloon plate, other than that means there is an automatic transmission in the car!
« Reply #4 on: May 01, 2020, 10:44:15 PM »
Put a clutch in it lol..
« Reply #5 on: May 01, 2020, 11:25:51 PM »
Maybe when I'm old.
« Reply #6 on: May 01, 2020, 11:27:45 PM »
Yeah, foot brake.  Just don't want it if it isn't necessary.  The extra cost is almost nothing.
« Reply #7 on: May 01, 2020, 11:28:34 PM »
I'll get it then.  Thanks.
paulie
« Reply #8 on: May 01, 2020, 11:30:52 PM »
Good video.  I think Hughes is usually considered a lower end converter manufacturer, or at least is known more for that.  That video made rethink that.  Thanks.
paulie
« Last Edit: May 03, 2020, 07:07:23 AM by plovett »
57 lima bean
« Reply #9 on: May 02, 2020, 08:22:13 AM »
      Hughes has been good to me the last few years.Munsinger was the best quality.
« Reply #10 on: May 02, 2020, 09:22:13 AM »
Interesting, thanks
KMcCullah
« Reply #11 on: May 02, 2020, 09:54:02 AM »
The way I look at it, an anti-balloon plate can save your mill (#3 main bearing) and your tranny. It's ugly in a C6. The gear that the torque converter hub engages with becomes a hole saw and cuts it's way out the back side of the pump. Fills the whole C6 with iron.
Kevin McCullah
