Author Topic: 482 FE  (Read 9084 times)
6667fan
  • Every Second Counts
482 FE
« on: April 24, 2020, 11:27:12 AM »
Performance Summary:
      Cubic Inches: 482              Dyno brand: Land and Sea DYNOmite
      Power Adder: none             Where dynoed: RAD Auto Machine
      Peak Horsepower: 636
      Peak Torque: 619
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 service block, (October '71) 4.25", 10.163, ARP main studs
   Crankshaft brand, cast or forged, stroke, journal size: Scat forged, 4.25
   Connecting Rods brand, material, center to center distance, end sizes, bolts: Scat I beam
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Mahle, forged, 9cc 11.3:1 confirmed with Whistler
   Main Bearings, Rod Bearings, Cam Bearings brand and size: Federal Mogul 125 mains, King rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle 1mm/1mm/2mm
   Oil Pump, pickup, and drive: Melling HV57, Canton pick up, ARP drive
   Oil pan, windage tray, oil filter adapter: Canton 15-180 with their tray, CJ adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050") Lykins MotorSports Custom Hydraulic Roller, 255/263@.050, 112 LSA, 635, 108 ICL
   Lifters brand, type: Morel limited travel
   Timing chain and timing cover: Cloyes double roller, Ford cover
   Cylinder heads brand, material, port and chamber information: Barry Robotnik CNC from 2018 EMC, 2.25/1.72,  72cc, .070 restrictors, Viton seals, Cometic .027 gaskets
      Intake               Exhaust
      .100               .100
      .200               .200
      .300 234         .300 150
      .400 276         .400 180
      .500 300         .500 198
      .600  325        .600 210
      .700  340        .700 213
      .750  345        .750 212
   Flow bench used, location: SF-600 RAD
   Intake valve brand, head size, stem size: 11/32" 137.3 grams
   Exhaust valve brand, head size, stem size: 11/32" 111.7 grams
   Valve springs brand, part number, specs: Comp beehive 520/195
   Retainers and locks brand, part number, specs:+.030 retainers, titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio: Erson, adjustable 1.76
   Rocker shafts and stands, brand, material: Erson
   Pushrods: Custom 11/32 .080
   Valve covers, brand, type: Mercury 1965 Lightning Bolt
   Distributor brand, advance curve information: MSD ready to run 18 degrees initial, 32 total
   Harmonic balancer brand: Innovators West, cut down sleeve spacer
   Water pump brand, type (mechanical or electric): Edelbrock
   Intake manifold brand, material, porting information: Dove tunnel wedge, massaged by Les Schmader, medium riser port sizes
   Carburetor(s) brand, type: QFT 715 cfm
   Exhaust manifolds or headers brand, type: Dyno headers 1-7/8 O.D.
« Last Edit: February 19, 2021, 08:55:14 AM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Re: 482 FE
« Reply #1 on: April 24, 2020, 12:36:23 PM »
Is this for your Fairlane? That's gonna be plenty stout for a street engine! Hope the rest of your drivetrain is up to the task :)
6667fan
Re: 482 FE
« Reply #2 on: April 24, 2020, 06:30:31 PM »
There are some questionable components Doug. An all aluminum, face plated TL waiting for Fed Ex to pick up from David Kee and a rear housing with 31 spline axles out of a 68 GT 350. We’ll see.
JB
JB
67 Fairlane 500
482 cid 700/617
Re: 482 FE
« Reply #3 on: April 24, 2020, 06:51:59 PM »
Great results! Thanks for posting.
Re: 482 FE
« Reply #4 on: April 24, 2020, 07:25:06 PM »
1.29 TQ/cid - pie package.  About 1700 RPM TQ peak to HP peak seems pretty solid too.  Nice piece.
6667fan
Re: 482 FE
« Reply #5 on: April 24, 2020, 08:04:13 PM »
Barry, what were the valve sizes? 2.20/1.75? I can’t recall. The builder was sure impressed with the heads.
The shop does a fair amount of FEs. This one made the most hp of any that have gone through there.
JB
JB
67 Fairlane 500
482 cid 700/617
Re: 482 FE
« Reply #6 on: April 24, 2020, 08:41:33 PM »
Can't recall for certain, but I suspect 2.25 and 1.720
John67427
Re: 482 FE
« Reply #7 on: May 15, 2020, 08:09:05 AM »
That’s going to be a powerful engine for your Fairlane. It will be fun!!!
6667fan
Re: 482 FE
« Reply #8 on: May 15, 2020, 09:36:45 AM »
John, I’m starting on a Long shifter install this weekend. Any tips, pics of the required Rhode Island sized opening?
Thanks.
JB
67 Fairlane 500
482 cid 700/617
Re: 482 FE
« Reply #9 on: May 15, 2020, 10:16:56 AM »
Next time you see RAD, tell them Ross Bullock, from Bullock's Repair in Ware said hello, and glad to see they are doing well.
We used to use them when they were in their small shop near Kmart on Rte 20 in Palmer, I left town almost 26 years ago, so it's been a while. I was a 25 year old kid when they saw me last. Not even sure if they would remember me, and I believe my dad drifted away from them when a machine shop oepned in Ware.
John67427
Re: 482 FE
« Reply #10 on: May 15, 2020, 10:55:06 AM »
Jim,
  I’ll try to get some for you. You can probably make it smaller but I remember getting frustrated and just wanted to get it done. That was 20 years ago....   Rods are very close to the left side of floor pan/ tunnel.
6667fan
Re: 482 FE
« Reply #11 on: May 15, 2020, 04:48:33 PM »
Ross, was Donnie the owner then? I was just there a lot in March/April for this build of course.They do a lot of circle track engines and have probably had half a dozen builds in MCR. When my engine was getting finished up there were two more 427s in there plus a pedestrian 410.
JB
JB
67 Fairlane 500
482 cid 700/617
