Author Topic: 31 spline axles  (Read 6238 times)
dmazz
31 spline axles
« on: January 15, 2013, 09:02:56 AM »
WTB 31 spline axles for 66 Fairlane GT 9inch.
fe66comet
Re: 31 spline axles
« Reply #1 on: January 15, 2013, 09:42:16 AM »
Housing will go but case has to be replaced and the Carrier. The big axle requires an aftermarket case to accommodate a larger bearing.
dmazz
Re: 31 spline axles
« Reply #2 on: January 15, 2013, 02:08:39 PM »
Thanks for the response, I have a complete Strange N case. I looked at new Strange and Moser online but I haven't pulled my axles to measure them. Just thought I'd check here to see if anyone had a set for sell.
fe66comet
Re: 31 spline axles
« Reply #3 on: January 15, 2013, 02:48:06 PM »
I would go with Currie stuff reasonable price and lots of options like taper housing end bearings. Heavy duty without the crazy mozier price.
Re: 31 spline axles
« Reply #4 on: January 15, 2013, 04:15:59 PM »
I like Currie Stuff also.
Lots of options and fair prices.
You may find that a 67 or later Mustang Axle set may fit your Fairlane Housing.
I think the difference is just the spring perches and where they where welded on.
Really though for the cost of new axles and fresh wheel studs and bearings, it`s pretty hard to beat a new set over
vintage.
My all custom Currie Heavy Duty Big Bearing 67 Fairlane setup.
No traction with the BFG`s but the rest of the gear works great.  ::)
fe66comet
Re: 31 spline axles
« Reply #5 on: January 15, 2013, 04:52:08 PM »
I am going.with the same set up but with Caltracs rear suspension to save weight. I like the Daytona big bearing option that Currie offers and the sportsman big bearing case nice combo with a 35 or 40 spline axle with taper bearing and late Torino ends, bullet proof.
dmazz
Re: 31 spline axles
« Reply #6 on: January 16, 2013, 08:20:52 AM »
Thanks for the info, I will check into Currie.
