Author Topic: Drew will be glad I finally did something with those 1850s  (Read 2656 times)
« on: April 08, 2020, 08:39:27 AM »
Finally got off my sitting position and put the old tunnel ram on top of the 351C in the Falcon.  Got it partially tamed, more tinkering needed but it seems to like it.  Still idling a bit high but idle mix is 10~12 in/hg which is normal for this cam, so I'm not far off.  Maybe need to re-set the carb blades and such.  Got ti running last night and will pull the carbs later and see where the slots, etc are before doing more changes.
