Author Topic: Lykins Motorsports 427MR, Factory Heads, Sidewinder, Hydraulic Roller  (Read 5572 times)
Performance Summary:
      Cubic Inches:  429             Dyno brand:  Stuska
      Power Adder:  No             Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  480 @ 5750
      Peak Torque:  490 @ 4250
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  BBM cast iron, 4.250" bore size, 10.150" deck
   Crankshaft brand, cast or forged, stroke, journal size:  Factory 390 crankshaft, 10/10
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar FE rods
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged, 16cc, 10:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  King AM559, Federal Mogul, Durabond FP-01
   Piston rings brand, size, other notes:  Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling HV, Milodon, ARP
   Oil pan, windage tray, oil filter adapter:  Milodon, no tray, factory style filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Lykins Motorsports hydraulic roller, 227/235 @ .050", 112 LSA, .580" lift
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory cover
   Cylinder heads brand, material, port and chamber information:  C5AE-F, cast iron, bowl/throat/roof work
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI 2.190", 11/32"
   Exhaust valve brand, head size, stem size:  SI 1.75", 11/32"
   Valve springs brand, part number, specs:  PAC dual spring, 160/420
   Retainers and locks brand, part number, specs:  Crane steel
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory non-adjustable, 1.73
   Rocker shafts and stands, brand, material:  Replacement shafts, POP end stands and factory center stands
   Pushrods brand, type, length:  Smith Brothers, 5/16", .116", 3/8" ball and 5/16" ball, various length
   Valve covers, brand, type:  Chrome pentroof
   Distributor brand, advance curve information:  Factory style distributor, in by 2800, Pertronix module
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Factory repop, cast iron
   Intake manifold brand, material, porting information:  Sidewinder, divider modification
   Carburetor(s) brand, type:  Holley 3310, with 1" Super Sucker
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: August 16, 2020, 05:50:24 PM by blykins »
6667fan
  • Every Second Counts
Re: 427MR, Factory Heads, Sidewinder, Hydraulic Roller
« Reply #1 on: April 10, 2020, 09:16:24 AM »
The output numbers match the back in the day figures. But it’s getting it done with less compression and cam. What size chambers on those heads?
Cool,
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
gt350hr
« Reply #2 on: April 10, 2020, 11:42:03 AM »
 Brent ,
    I know you build to very specific needs.  With the HP being less than TQ "to me" more cam would have made more HP and less TQ . Probably not what your customer wanted but I was "thinking".
    That is a very strong "street" 427. nice work!
   Randy
« Reply #3 on: April 10, 2020, 06:55:21 PM »
Cool,
JB
Jim, the chambers measured around 71cc.
« Reply #4 on: April 10, 2020, 06:56:15 PM »
Brent ,
   Randy
Randy, it was cam-poor for sure.  Only 227° @ .050".  Heads worked well as that little 227° cam peaked at almost 6000.
« Reply #5 on: April 10, 2020, 07:01:36 PM »
gt350hr
« Reply #6 on: April 13, 2020, 11:19:23 AM »
   MORE HP and TQ than an original with LESS cam , THAT is even more impressive! Nice work.
