Author Topic: Lykins Motorsports 447FE with Trick Flow heads....  (Read 7678 times)
« on: April 07, 2020, 02:16:09 PM »
Performance Summary:
      Cubic Inches:    447           Dyno brand: Stuska
      Power Adder:     Nope          Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  547
      Peak Torque:  588
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 390 block, 4.090", 10.150"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4.250", 9000 series
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat I-beam, 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle, forged, 18cc, 10.3:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 125M, 8-7200CH, Durabond F33
   Piston rings brand, size, other notes:  Mahle, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling HV, ARP drive, Canton pickup
   Oil pan, windage tray, oil filter adapter:  15-850 Canton, no tray, repop oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Lykins Motorsports hydraulic roller, 231/239, 114 LSA, .630"
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory cover
   Cylinder heads brand, material, port and chamber information:   Trick Flow, aluminum, OOTB port work, 69.8cc chamber
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  2.190", 11/32", 5.500"
   Exhaust valve brand, head size, stem size:  1.625", 11/32", 5.500"
   Valve springs brand, part number, specs:  PAC dual spring, 150/400
   Retainers and locks brand, part number, specs:  Crane steel retainer
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports non-adjustable roller tip, 1.76
   Rocker shafts and stands, brand, material:  Harland Sharp HD, Precision Oil Pumps stands and spacers
   Pushrods brand, type, length:  Trend, 5/16", .105", various lengths
   Valve covers, brand, type:  Black Cobra Lemans
   Distributor brand, advance curve information:  MSD Pro Billet, all in by 2800
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Tuff Stuff aluminum
   Intake manifold brand, material, porting information:  Edelbrock Performer RPM, divider modification
   Carburetor(s) brand, type:  Quick Fuel HR-780
   Exhaust manifolds or headers brand, type:  2" tube dyno headers
« Last Edit: August 16, 2020, 05:49:59 PM by blykins »
Re: 447FE with Trick Flow heads....
« Reply #1 on: April 10, 2020, 07:05:04 PM »
« Reply #2 on: April 10, 2020, 07:08:00 PM »
Am I wrong in seeing 20-25hp on average with your builds bbm vs trick flow?
« Reply #3 on: April 10, 2020, 07:45:16 PM »
Yep, 20-25 hp more with TFS heads with less camshaft.
57 lima bean
« Reply #4 on: April 12, 2020, 12:33:37 PM »
Who's headers in the photo?
« Reply #5 on: April 12, 2020, 12:58:29 PM »
FPA
Joey120373
« Reply #6 on: April 13, 2020, 10:32:57 AM »
Very nice looking build.
OOTB? Out Of The Box?
Do you remember what the rpm peaks were?
« Reply #7 on: April 14, 2020, 09:02:53 AM »
Yes sir, out of the box.
Horsepower peak was 5750 and torque peak was 4500.
