Author Topic: Clutch replacement  (Read 3066 times)
Dan859
Clutch replacement
« on: April 04, 2020, 12:10:00 PM »
Hi Everyone,
I'm looking for input on a new clutch for my 66 Fairlane.  It's a Ford Motorsports 351 block, 393 CID.  It dynoed 376 HP at the rear wheels, so I'm figuring about 425 HP at the flywheel.  Transmission is a TKO 600, rear end is a 9 inch with 3.75 posi gears.  The car is street driven, but I might take it to the track once, just to run it and get some time slips.  I would appreciate any suggestions for a new clutch, and maybe a flywheel if I end up needing one.  Thanks in advance.
Dan
Re: Clutch replacement
« Reply #1 on: April 04, 2020, 12:11:19 PM »
Which bellhousing and which pattern does your flywheel have?
If you can run an 11” Long, I’d run a RAM 88769HDT.
Dan859
« Reply #2 on: April 04, 2020, 04:42:53 PM »
It's a quicktime bellhousing, but I don't have it apart yet, so I don't know what the pattern is.
