Author Topic: cross ram  (Read 13647 times)
gdaddy01
cross ram
« on: April 01, 2020, 04:40:26 PM »
there is a cross ram fe on craigslist for 750 dollars and my mouth is watering to hit buy it now , someone talk me out of it , please . I know it is not the best intake by Jays book , but I do like the looks of those things . would just run it on the street in my 62 ranchero gasser .
Re: cross ram
« Reply #1 on: April 01, 2020, 04:56:52 PM »
At $750 I'd buy it, makes a bunch of torque on a strong engine and the looks can't be beat.
C8OZ
Re: cross ram
« Reply #2 on: April 01, 2020, 07:17:43 PM »
If it's the MT, make sure it includes (or you have a line on) the distributor setup. Mine used an old Mallory that had been machined to fit, plus the pump drive extension and spacer. Love the look.
gdaddy01
Re: cross ram
« Reply #3 on: April 01, 2020, 09:09:57 PM »
thanks , guys , it is an edelbrock .
gdaddy01
Re: cross ram
« Reply #4 on: April 01, 2020, 09:11:42 PM »
it is on e bay , not craigslist , my mistake
Re: cross ram
« Reply #5 on: April 02, 2020, 01:31:17 AM »
As i remember it from the book, the Edelbrock was better than
the M/T
BigBlueIron
Re: cross ram
« Reply #6 on: April 02, 2020, 08:10:14 AM »
One day I will own one. By the time that day comes they will probably be going for 4k
FERoadster
Re: cross ram
« Reply #7 on: April 03, 2020, 12:15:40 AM »
Sorry JayB but cross ram looks  can be beat.
I've got both a MT and an Edelbrock Cross ram  and the Edel. 6X2 looks  better in my opinion.
Performance ??? but looks ------
Richard
gdaddy01
Re: cross ram
« Reply #8 on: April 03, 2020, 11:05:51 AM »
now where is the picture of the other two , where we can compare ?   It sounds like I am a little like you , I like the looks of them all or I would stop trying to buy more , more , more .
FERoadster
Re: cross ram
« Reply #9 on: April 03, 2020, 11:35:39 AM »
Here is a picture I took 2 years ago when getting ready to evac. for a wildfire. I've only sold the BT 2X4 and the TBird 3X2. I've got a few more multi carb setup's that didn't get into the picture.
Tommy-T
Re: cross ram
« Reply #10 on: April 04, 2020, 10:26:01 AM »
How about a cross ram with a bunch of carbs? I call it my quad dual or hillbilly split dominator.
dozz302
Re: cross ram
« Reply #11 on: April 04, 2020, 10:36:52 AM »
WOW that's really neat looking!
pbf777
Re: cross ram
« Reply #12 on: April 04, 2020, 10:53:40 AM »
     Now that's thinking outside the box!
     If this is the Edelbrock X-F66 intake, I might suggest flipping the carburetors on one side so that they are opposed from right to left, so that the presentation is symmetrical for the two engine banks.  One would at least initially believe that if the throttles in tipping pointed outward (toward the valve covers) into the plenum you would potentially experience the effect of lengthening the inlet distance to the inlet valve, and flipping the carburetor(s) so that the throttles in tipping pointed inward more pointed at the inlet valve would effectively shorten it.  Believe me, the throttle angle has a significant effect on the flow presentation within the plenum area to the port runners.
     Yep, makes the throttle linkage a pain, but you got it this far!          ;D
     Scott.
Re: cross ram
« Reply #13 on: April 04, 2020, 11:52:37 AM »
I think Tommy's setup probably works better than a single 4 on each side.  The big issue with either of the crossram intakes is fuel distribution to the outside cylinders, and his arrangement solves that.  The other thing that I've always thought would work would be to put an EFI individual injector setup on one of those intakes, which would also solve the fuel distribution problem.
Tommy-T
Re: cross ram
« Reply #14 on: April 04, 2020, 01:19:40 PM »
Interestingly enough, I have been in touch with Blair Patrick as he was dyno testing a 482 with a M/T cross ram. He said in testing he found that the outer cylinders ran very rich which is counter intuitive to what one might think.
It could be the answer as to why the Edelbrock cross ram runs better. The squared off ends of the plenum on the Ed unit might this from happening.
As far as turning the carbs around on my manifold goes, I'm not going to do it. I've got more invest in this experiment than I want to and I am skeptical on what the results may be. It'll be nifty at car shows and a tunnel ram equipped 482 is waiting in the wings for when I'm done with this mess. If you're interested in the motor this manifold is going on, the specs are in the Members Projects section of the FE Forum in my Comet's build up.
Fun!
