Non-FE Discussion Forum
what rear sump pump would you use?
Topic: what rear sump pump would you use? (Read 2933 times)
james
Jr. Member
March 31, 2020, 05:04:27 PM »
I need advice on what rear sump pump would you use with a Jon Kasse 460 semi hemi engine? Also what pickup would you advise. Someone told me about this one but I'm not sure. Canton 15-770 and the pickup is 15-771. Another guy mentioned Moroso. It's going in a 1966 mecury comet cyclone. Thank You!
Re: what rear sump pump would you use?
Reply #1 on:
March 31, 2020, 05:08:15 PM »
This will get moved because it’s not FE but until it does...
The pan and pickup don’t matter as much as the pump. I would use one of Jon’s oil pumps made for the rear sump pan.
As for the pan, Canton, Milodon, or Moroso all would be good choices.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
