Author Topic: Plug change. Heat range too hot?  (Read 4143 times)
67428GT500
« on: March 13, 2020, 02:50:22 AM »
I have been running FR4 plugs with the Edelbrocks heads. The Edelbrock recommended plug is a Champion RC12YC.  I have never had a Champion plug I liked and I saw many of them being returned due to failure in vehicles.  Two plugs were recommended here. One is the NGK FR4, the other BKR6E.  Remember, this is a factory dual quad car that is street driven with the occasional "blast".  There is some soot on the body, which I am a bit rich but much I see a lot of gray on the electrode and ground. I had a set of BKR6E in my cabinet. Any reason not to run them?
Is there another recommendation?  I might add that I am also running the Pertronix II and matching coil. Direct 12V power source to the module as instructed. The compression ratio is about 9.8:1.
Any suggestions would be welcome.
Re: Plug change. Heat range too hot?
« Reply #1 on: March 13, 2020, 06:20:09 AM »
I have run the Champions and 3924 Autolites, almost every one ends up with the Autolites because you can get them anywhere and cheap, both work fine on the street though. I will throw a set of the race version 3924R in now and then, but I don't see any real benefit when I do.
I see no reason your NGK won't work just as well
« Reply #2 on: March 13, 2020, 10:55:13 PM »
Back in the day, running the Thunderbolt, we were given plugs by the case. We quickly found that it was necessary to change Champs after every run,
A switch to a case of Autolite resulted in being able to run a set of plugs all day. We'd change them Saturday night in preparation for Sunday. The only drawback to the Autolites was that in order to get a new case of plugs, we had to bust the porcelain out and return the steel shells. We rigged up a holder in a HD shop vise and just gave them a lick to punch the core out. I can still see the burn marks on my arms from changing Champ plugs on a hot engine between rounds.
67428GT500
« Reply #3 on: March 14, 2020, 12:52:29 AM »
I can't even imagine doing that on an FE mustang with power brakes between rounds. With the factory Cobra -Le Mans cast pent roof covers you're lucky to get the plug wires back on correctly.
