Author Topic: D4TE 105 blocks. Distributor bushing?  (Read 9743 times)
67428GT500
« on: March 11, 2020, 10:47:35 PM »
I am trying to get clarification. Understand the true FT blocks have a compressor drain back to the block. Is that how the blocks are identified that need the distributor? It wasn't measured previously to assembly.
countrysquire
    • Houston Vapor Blasting
Re: D4TE 105 blocks. Distributor bushing?
« Reply #1 on: March 12, 2020, 01:46:11 PM »
My D4TE block has the compressor drain hole on the passenger side skirt, but has the 'automotive' size hole for the bottom of the distributor.  I was expecting to need a bushing, so I was surprised by this.
67428GT500
« Reply #2 on: March 12, 2020, 10:43:11 PM »
It's confusing and I should have taken the precaution and measured. I understood it was only blocks used with dump trucks and such.
« Reply #3 on: March 13, 2020, 12:51:44 AM »
Mostly 331, 361, 391 truck blocks but there are several others. I'm just naming the most popular ..  ::) give me a break guys lol..
Riderjeff
« Reply #4 on: March 13, 2020, 11:27:25 PM »
I just took my D4TE block down to the machine shop last Saturday, and just before leaving I did a quick and dirty measurement of the distributor hole using drill bits to check the ID.  Seemed to me it was an easy fit for a 7/16” shaft. Can anyone tell me if that’s the large or small hole? My rebuilder block didn’t come with a distributor.
Riderjeff
« Reply #5 on: March 19, 2020, 03:05:19 PM »
Sorry for being such a newb, but still looking for an answer to this.
THX
« Reply #6 on: March 20, 2020, 03:15:54 AM »
THX
I can take meassures later today
« Reply #7 on: March 20, 2020, 12:58:45 PM »
A 7/16 bolt is a loose fit, 1/2 is a no go on a passenger block
Riderjeff
« Reply #8 on: March 20, 2020, 02:36:51 PM »
So, is the 7/16" hole a "passenger" distributor hole, and a 1/2" a truck/HD sized hole?  Thanks for checking, but not having more than one block lying around, I can't compare one to another.  I think I'll get hold of POP to maybe clear this up.
Tom Gahman
« Reply #9 on: March 20, 2020, 07:05:25 PM »
Rider, a29/64 drill bit is a nice fit (.448)
A used fe distributor is (.450)
Hope this helps you.
 tom
Passenger car
« Last Edit: March 20, 2020, 08:14:42 PM by Tom Gahman »
« Reply #10 on: March 20, 2020, 07:37:58 PM »
The bushing Ford used to service to adapt the FT block for a FE sized distributor is part number C4TZ-12367-A. I measured the O.D. of an NOS bushing and it is .518”
« Reply #11 on: March 21, 2020, 11:23:53 AM »
Yes 7/16 + is passenger
wsu0702
« Reply #12 on: March 21, 2020, 12:34:57 PM »
I made this a while back when this question was coming up frequently on my FB FE group.
Riderjeff
« Reply #13 on: March 21, 2020, 01:21:42 PM »
Interesting, as there's no doubt of the D4TE casting.  The date code is a little muddled, pretty sure it's January '76.  So, looks like a passenger-type dizzy.
So easy to get misinformation, I emailed Precision Oil Pumps who makes a repop bushing.  They assured me that it's a truck block and I'd need the bushing.
Thanks for all the help, everyone!
wsu0702
« Reply #14 on: March 21, 2020, 03:19:05 PM »
I think you are confusing the car vs truck aspect of this when you say "passenger" block.  D4TE blocks where mostly (95+%) used in light trucks (F150-F350s).  These engines all used the regular FE distributor and therefore have the smaller hole.  The only engines that used a different distributor with the larger shaft (bigger holes) were the medium and heavy duty truck (and some U-haul light truck) FT engines.
