FE Technical Forum
Adjusting Top Loader Shifter Linkage.
Topic: Adjusting Top Loader Shifter Linkage. (Read 3068 times)
67428GT500
March 07, 2020, 08:57:06 AM »
I made the tool to lock the shifter. However, Ford didn't spell out the procedure. I assumed what needed to be done is all three levers should be in neutral. The shifter locked in neutral and the rod nuts tightened. Did I miss anything?
Last Edit: March 08, 2020, 12:55:25 AM by 67428GT500
Re: Adjusting Top Loader Shifter Linkage.
Reply #1 on:
March 07, 2020, 09:50:42 AM »
That’s it, you may need to adjust stops if not fully engaging after, but pretty straightforward
FE Technical Forum
