Author Topic: WTB 4 SPECIAL HEAD BOLTS 4 DOVE HD ROCKERS  (Read 5323 times)
DEANs427
« on: March 06, 2020, 10:46:18 AM »
Looking for the 4 special head bolts used with the Dove hd/ wide body rocker set-up.
Dean 612 245 930five
« Last Edit: March 06, 2020, 09:54:40 PM by DEANs427 »
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
GJCAT427
Re: WTB 4 SPECIAL HEAD BOLTS 4 DOVE HD ROCKERS
« Reply #1 on: March 07, 2020, 07:25:39 AM »
Are you talking about the bolts with the end mount spacers? They hold the end stands for the rocker shaft? I had to remake one of mine that was welded on crooked from Dove. I used a grade 8 bolt just like what was used from the factory made a new spacer and welded it up. Put it in and no problem so far. It helps to have a machine shop for truing up and jigging them to be welded.
« Reply #2 on: March 07, 2020, 10:03:18 AM »
Call Dove and see if they have any
ntheogen
« Reply #3 on: March 08, 2020, 12:09:56 AM »
Dean, check the buyer beware board on this forum about buying things for Dove these days.
Henrysnephew
« Reply #4 on: March 09, 2020, 06:31:59 PM »
Dean, is this what you're after?  They're from a Dove setup I ran many years ago.  If so, I'll send you an email.  Randy M
« Last Edit: March 09, 2020, 06:33:57 PM by Henrysnephew »
DEANs427
« Reply #5 on: March 10, 2020, 12:01:28 AM »
Randy,
can you get the dimentions of that stud, I think that will work, need 5/16 on the skinny end...also length of 1/2 " part
Than you, Dean
dmdb1969@gmaildotcom
1966 Fairlane
Henrysnephew
« Reply #6 on: March 10, 2020, 08:17:36 PM »
  Dean, the upper part is 3/8" fine thread.  The lower length is equivalent to a conventional long head stud.  As I recall a couple of hardened washers/shims were used on top of the stud nut to bring the end support mount surface up to the level necessary for end support alignment with the rocker shaft.
  If these (four) will work for you I'd be happy to trade you for four conventional upper (long) studs if you've got four spares.  If you don't have any to trade you can have these anyway, as you did me a solid last year on that Big F medium riser head.  Let me know - I still have your mailing address. Randy M
DEANs427
« Reply #7 on: March 11, 2020, 09:22:29 AM »
Randy, looks like they will work for me, I do not have any studs for exchange, send them when you can, i will send a check back.
Thank you so much,
Dean
1966 Fairlane
Henrysnephew
« Reply #8 on: March 11, 2020, 06:25:26 PM »
OK, I'll ship Friday.  Randy M
