Author Topic: 1966 Mercury Cyclone  (Read 8114 times)
THCBSC
« on: March 05, 2020, 10:16:15 PM »
390  .030 over Diamond pistons 12.5:1 Comp
TF stock heads and manifold
4.125 Scat 4340 crankshaft
HS Rockers
4.44 gears Detroit Locker
35 Spline Strange axles
MT 29.5 X 9 Slicks
Jerico 4 Speed V-Gate
Modified Caltracs, with leaf spring sliders (with roller bearings) and mono parabolic springs (2 inches wide)
Mark 12 pressure plate with organic disc (going to sintered iron)
https://www.youtube.com/watch?v=astOEwyo3fI
https://www.youtube.com/watch?v=gKmXpE2lCfU
I added a video of the suspension, the only run I used the Go Pro camera in 2019 which happens to be the attached time slip also for this run.  I also added one other run at the track.
« Last Edit: March 21, 2020, 07:31:54 PM by THCBSC »
Re: 1966 Mercury Cyclone
« Reply #1 on: March 06, 2020, 02:51:56 PM »
Very nice good looking car. Which time is yours? Either one is great.
THCBSC
« Reply #2 on: March 06, 2020, 04:22:14 PM »
Thank you, the left lane with the .005 light.
« Reply #3 on: March 06, 2020, 05:21:26 PM »
Nice but of course that one is better ;)
« Last Edit: March 06, 2020, 05:23:26 PM by Stangman »
351crules
« Reply #4 on: March 06, 2020, 10:16:01 PM »
nice pass...what are you running for a cam..what size carb
THCBSC
« Reply #5 on: March 06, 2020, 10:42:14 PM »
Crane cam 306 In/314ex .658 lift for both (std.1.76 rocker ratio), Holley Ultra XP, 950
475fetoploader
« Reply #6 on: March 06, 2020, 10:46:22 PM »
That is most excellent! Great looking run.
1967  519 c.i.  TKX 5 speed
6667fan
  • Every Second Counts
« Reply #7 on: March 08, 2020, 04:42:48 PM »
Nice R/T, great run. What is the displacement now and what fuel do you feed it?
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
THCBSC
« Reply #8 on: March 08, 2020, 08:43:33 PM »
It is roughly a 431.5 CU IN motor.  I use VP MS109 which is an oxygenated fuel, however I run that fuel for primarily 2 reasons.  The first is you don't have any carbon build up on your pistons and it evaporates so quickly it never washes the oil off your cylinder walls after you shut off your engine.  The free bonus for me is it adds a little HP.  Because my clutch has been slipping since I built the motor, I haven't had a full run yet on the motor.  I have the rev limiter set at 6,400, the engine will to go 7,100.  When I put the sintered iron disc in along with the new pressure plate I'll know what the car can do, assuming I don't start breaking things.
Posi67
« Reply #9 on: March 08, 2020, 11:15:02 PM »
I like it but then I'm also a fan of 390's, 4speeds and Cyclones. An adjustable clutch will certainly help with the 60' times and lower ET's while being less likely of breaking driveline parts. Gotta ask though..  where did you leave your race jacket? Thanks for the post..
Cobrajet2
« Reply #10 on: March 10, 2020, 08:45:03 PM »
Nice pass! Looks to be leaving pretty hard. Probably a bunch of fun to drive down the track.
Mike
