Author Topic: Eaton Fuller Transmissions FS4005C Main And 3-C-65 Auxiliary Transmission.  (Read 3395 times)
chris401
Would any of you mind getting a few measurements for me? I have the length and weight off Eaton's website. I need the center of shaft to bottom of case height and center shaft to top of case height. The "C" is just the gear ratios so any letter would be close enough to work.
Thanks
chris401
