Non-FE Discussion Forum
Coolant temperature rises after exiting freeway?
Topic: Coolant temperature rises after exiting freeway? (Read 3636 times)
67428GT500
March 01, 2020, 04:37:31 PM »
I have been doing primarily street driving. I have started doing short freeway runs. Being it turns 3500 at 70, I haven't taken it on a long trip.
I have been noting that when I come off the freeway and hit a few lights that the temperature starts running about 20% higher on the gauge for about 20 minutes post exiting. Is there a reason for this?
-Keith
jmlay
Full Member
Re: Coolant temperature rises after exiting freeway?
Reply #1 on:
March 01, 2020, 05:44:22 PM »
Less airflow due to slower speed. When stopped the coolant flow is less as well as lower airflow.
Mike
67428GT500
Reply #2 on:
March 01, 2020, 09:13:09 PM »
Yes, I agree. However, if I stay on the street it stays about the same regardless. It's just after I make a run on the highway where I am running at 3200-3500 and get off it comes up and stays that way for 20 minutes or so post.
68fecyclone
Jr. Member
Reply #3 on:
March 01, 2020, 09:28:46 PM »
Do you know what the oil temp is, I would bet it gets pretty warm. When you slow down the cooling system is soaking up that heat. Just a gues on my part. Rob
