Author Topic: Ross Pistons 428 4.162 bore/4.250 stroke  (Read 3150 times)
aj
« on: February 29, 2020, 01:47:10 PM »
For Sale:  Barely used flat top forged Ross pistons for 428 using 4.250 stroker crank.
Ross #XL 412-2
Bore: intended for 4.162 bore
Weight with pin: 588g
Weight with pin,rings,locks: 645g
Compression Height 1.312
Rings: 1/16, 1/16, 3/16
Top ring is 0.250 below top of piston
Pin:   .990 diameter
         2.93 wide
         .148 pin wall thickness
These pistons used for 4 dyno pulls.  Decided to reduce compression so swapped to dished pistons.
$400.00 and will split shipping cost if in US. If interested,  PM me or call/text 97two-67two-2811
I can text or email additional photos (or if attached photos aren’t working properly)
« Last Edit: March 04, 2020, 08:36:26 AM by aj »
Adrian Jacobs
Weatherford, TX
1970 Shelby GT500
1970 Boss 302
XR7
Re: Ross Pistons 428 4.162 bore/4.250 stroke
« Reply #1 on: March 01, 2020, 12:46:43 PM »
texted you...
