Author Topic: You guys with 65-67 Galaxies and Quicktime bellhousings....  (Read 3362 times)
« on: February 28, 2020, 04:27:37 PM »
….what are you doing with the Z-bar pivot?  It's made into the bell on a factory piece, but there is no provision on a QT bell.
AlanCasida
Re: You guys with 65-67 Galaxies and Quicktime bellhousings....
« Reply #1 on: February 28, 2020, 11:21:09 PM »
This is what I built for my 66 Galaxie when I had the 428 4 speed in it using a Lakewood bellhousing. I used some flat metal to build the bracket. The bottom and top bolt holes of the bracket caught the two bellhousing mounting bolts. The third hole was for the block plate. The pivot ball is for a ford truck. I replaced both pivot balls with this setup since those split teflon ball bushing for a 65-67 Galaxie were impossible to find.  Hope this helps.
« Last Edit: February 28, 2020, 11:34:56 PM by AlanCasida »
« Reply #2 on: February 29, 2020, 05:18:42 AM »
Thanks Alan!
« Reply #3 on: February 29, 2020, 09:13:04 PM »
Why did Ford quit using the bracket on the block?  I'm guessing because of geometry and motor placement?
I know they make a bracket for SBF because of the lack of pivot ball mount on the newer blocks.
