Author Topic: Maximum Horsepower for Base Block  (Read 3500 times)
410bruce
« on: February 24, 2020, 08:27:54 AM »
Hey guys. At what point are the base, non-reinforced main cylinder blocks considered not advisable to use? Street or race use.
Thanks.
John 3:16
Re: Maximum Horsepower for Base Block
« Reply #1 on: February 24, 2020, 09:07:25 AM »
When they split in half.....LOL
There's really not a number that you can put on a block as to when it will fail.  It depends on the rpm, horsepower, etc., etc.  Some of them may live at 700 hp, some may split at 600.
410bruce
« Reply #2 on: February 24, 2020, 09:12:28 AM »
Cool. Thanks Brent. :)
John 3:16
« Reply #3 on: February 24, 2020, 09:27:57 AM »
I have a couple 428 blocks that are cracked up the mains. One was raced, but I know it wasn’t making anywhere near 600hp, the other I don’t know the history of, but no evidence it was a high horsepower engine either. Both have the three finger main webs.
410bruce
« Reply #4 on: February 24, 2020, 09:44:41 AM »
Wow! I wonder what would cause that? Is that repairable?
John 3:16
« Reply #5 on: February 24, 2020, 10:09:43 AM »
Truth for all stock blocks IMHO.  I've seen 302 blocks go 2~3 seasons with 500+ HP N/A and a 150 shot every pass and seen same blocks go 4 passes at under 500 HP and then fall apart.  Same like rear ends LOL - a guy I know that raced a Cougar - 351W, low 11's - ran wheels up every pass on an 8" rear pig with 28 spline axles.  3rd year he finally spit the pinion out.  Most of the Ford people I know that race are using aftermarket blocks.  You just never know.  The spare 302 makes around 300 ish, I put that one together in 1995.   I had a 351C that went 2 seasons and split 5 cylinder walls plus exhibited major cap walk, the 351C in the Falcon has been raced since 2006, has 3000+ rounds on it.   Like a Timex watch LOL.  [ Immediately runs around knocking on every piece of wood in the office]
« Last Edit: February 24, 2020, 10:11:28 AM by Falcon67 »
