Author Topic: Noisy lifter  (Read 5191 times)
blackthunder1970
Noisy lifter
« on: February 17, 2020, 03:34:32 PM »
Hi guys
A couple of questions
First one is can I just change the lifters and still use the original factory cam
Second one is how hard is it to change the lifters with the intake still one and is it doable
Thanks
Barry
Re: Noisy lifter
« Reply #1 on: February 17, 2020, 04:00:14 PM »
Depends on the intake - often very do-able.
Distributor hole is a good access point for some, and a great place to put a flashlight in when working on other locations.
blackthunder1970
Re: Noisy lifter
« Reply #2 on: February 17, 2020, 04:09:56 PM »
Hi Barry
So is ok to use new lifters on a old cam shaft
preaction
Re: Noisy lifter
« Reply #3 on: February 17, 2020, 04:50:36 PM »
I have had good luck just changing oil brands to help with a ticking lifter.
blackthunder1970
Re: Noisy lifter
« Reply #4 on: February 17, 2020, 05:27:50 PM »
Try that chhanging oil
preaction
Re: Noisy lifter
« Reply #5 on: February 17, 2020, 07:17:39 PM »
Different brands of oil have different packages of additives and some are better than others I went from Valvoliene to Pennszoil and my ticking went away.
Re: Noisy lifter
« Reply #6 on: February 17, 2020, 10:06:31 PM »
If it doesn't quiet down with an oil change, yes, you can swap lifters.  However, be sure it's not a bent pushrod or somehow damaged lifter.  The noise has to be coming from the plunger bleeding down, not from physical damage.  If a bottom of the lifter is wiped, it will make short order of a new on
I prefer to do it intake off so I can lube them up good, but you can probably snake them in with patience
shady
Re: Noisy lifter
« Reply #7 on: February 18, 2020, 10:17:27 AM »
Man, I hate to sound like a broken record, but make sure it isn't the fuel pump. I watched a guy change a cam and lifters for a ticking fuel pump.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
StarlinerRon
Re: Noisy lifter
« Reply #8 on: February 23, 2020, 12:23:31 AM »
I'd try a can of RISLONE first. It is possible to change one lifter w/o removing the intake, just a pain though.
Ron
Ranch
Re: Noisy lifter
« Reply #9 on: February 23, 2020, 07:48:15 AM »
I'm with Ron, I'd try flushing the system.  Years ago my brother came home with a 67 Chebby with a a ticking, changed the oil ran it for a few days, didn't go away. So we ran some crankcase flush thru it, took about 15 minutes and the ticking was gone.  Of course oil back then was like .50 cents a Qt, so the job cost like 5 bucks....JMO
