Author Topic: Hardened Steel Distributor Gear  (Read 7755 times)
MExpress
« on: February 15, 2020, 07:42:16 AM »
I'm getting conflicting answers regarding running a hardened steel distributor gear with a cast iron flat tappet cam.
From what I've been reading some say it is compatible and others say no.
Which is it?
Re: Hardened Steel Distributor Gear
« Reply #1 on: February 15, 2020, 07:54:48 AM »
It depends, there are many different gears out there.  If it is a melonized iron gear, you are likely OK, but I would ask the gear manufacturer.
« Reply #2 on: February 15, 2020, 08:30:19 AM »
Hardened steel?  No go.  You need a cast iron gear.
MExpress
« Reply #3 on: February 15, 2020, 04:52:35 PM »
 Thanks Brent.
That's what I figured.
I just installed the iron gear as suggested.
« Reply #4 on: February 17, 2020, 09:52:32 AM »
I prefer to run brass or composite and check them once in a while.
« Reply #5 on: February 17, 2020, 10:20:03 AM »
Steel = steel, cast iron = cast iron.  Never have to check.
Bronze is for Chevys.  :)
pbf777
« Reply #6 on: February 17, 2020, 01:10:15 PM »
  If it is a melonized iron gear...........
    This is GM terminology and technology, and although this vocabulary is popularly implied to The Ford product, it didn't exist, until perhaps Comp-Cams, so confused with what their cam cores were being made of, and therefore unknowing of what to recommend as far as distributor driven gear material, did as has been so commonly practiced in the past, "if it works for the Chevy's just close your eyes and sell the same $het to the Ford guys"!  But your still stuck with the question.............is it the correct gear material for your application?       :o
     Scott.
« Reply #8 on: February 17, 2020, 10:11:51 PM »
     Scott.
Not sure what you are getting at here, not really a Chevy thing, a hardening thing.  I brought it up because many "roller cam" gears are often melonized iron unless specifically listed as steel.
Best bet is as Brent said, steel on steel, iron on iron.  I am not a bronze fan, seen too many towed in and the teeth pulverized into somewhere.  Amazingly, it never seemed to hurt anything, but that's a lot of material.  Haven't tried composites
« Reply #9 on: February 18, 2020, 09:42:24 AM »
I already lost one cam from steel on steel eating each other up, not going $300 in the hole again.  I'll stick with Chevy bronze.  I just checked the one in the dragster motor after two season, looks fine.
« Reply #10 on: February 18, 2020, 09:59:30 AM »
Well, when you only go a 1/4 mile, it's gonna look fine LOL....500 passes is just 125 miles.
The second biggest issue that I see, aside from wrong materials, is when guys install them wrong.   Not saying that's what you did, but most guys think that you can pop one off and put the new one on right back in the same spot, pop the pin in, and you're done.  Fords are much more sensitive to this install dimension and it can mean life/death on a gear.  You'd be surprised at how many people mess this up.   I bought a distributor off of a pretty well-known Cleveland engine builder once, dropped it in the engine, and fired it up on the dyno, only to immediately watch the spark plug wires get wadded up as the distributor turned.
« Last Edit: February 18, 2020, 10:25:12 AM by blykins »
« Reply #11 on: February 18, 2020, 03:18:35 PM »
LOL - 62.5, I only run 1/8 mile.  So even less wear and tear.  Terrible gas mileage though...
« Reply #12 on: February 18, 2020, 10:31:08 PM »
Want to have fun with that sort of math?
Calculate the lifespan of a top fuel engine in RPM.
They turn maybe 8000???
For under 4 seconds
Give them an extra two seconds for burnout and 10 for backup/stage at 2000
Then they get rebuilt.
Thats what - 1000-1200 crank rotations total?
« Reply #13 on: February 19, 2020, 07:52:32 AM »
For under 4 seconds
It's a Chrysler design, what do you expect?  :)
BigBlueIron
« Reply #14 on: February 19, 2020, 09:31:26 AM »
For under 4 seconds
Ha!
A friend has a nitro funny car, he was telling me some of these numbers. It's truly unbelievable.
