Author Topic: Tunnel Wedge bottom cover gasket  (Read 4526 times)
« on: February 13, 2020, 08:27:39 AM »
Anyone know if someone is making the bottom cover gasket for a Ford TW?  or if BBM or Dove is available and the same?
Got some time, but would rather not make one if someone else does :)
6667fan
  • Every Second Counts
Re: Tunnel Wedge bottom cover gasket
« Reply #1 on: February 13, 2020, 08:38:26 AM »
Ross, not comfortable with RTV of your liking there?
Don’t like the look?
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #2 on: February 13, 2020, 08:43:12 AM »
Silly-cone.  It's what I use on the Ford and BBM plates.  The BBM is actually o-ringed, but I generally don't use it.
« Last Edit: February 13, 2020, 09:19:06 AM by blykins »
« Reply #3 on: February 13, 2020, 04:23:43 PM »
JB
I am generally anti-RTV as much as I can be.  Especially with a tin plate against a machined surface.
GerryP
« Reply #4 on: February 13, 2020, 04:38:07 PM »
...I am generally anti-RTV as much as I can be.  Especially with a tin plate against a machined surface.
Have you considered an anaerobic gasket sealer/maker?
Mistral_427TP
« Reply #5 on: February 14, 2020, 07:05:11 PM »
Try DSC, they might have some.
http://www.dscmotorsport.com/asp/Products/popup_PartDetails.asp?PartID=705
-Johnex Cobra Replicar
« Reply #6 on: February 15, 2020, 07:35:53 AM »
Thanks!  I forgot about him, I will get in touch.  I appreciate it
