Author Topic: Wanted: FE Manual Bellhousing  (Read 7599 times)
allen2438
« on: February 11, 2020, 08:07:33 AM »
I need a FE CAR bellhousing, NOT truck, for a toploader trans.  Previous owner used a truck bell and lunched the input bearing and pilot bushing.  "knapp489@gmail.com"
In the central Tx area.  Allen
yellercat
Re: Wanted: FE Manual Bellhousing
« Reply #1 on: February 12, 2020, 02:01:33 PM »
What is the easiest way to tell the difference in the auto vs. truck bell housings, Allen?
Brad
52' F-1
69' Camper Special
70' F-100
88' F-150
« Reply #2 on: February 12, 2020, 02:20:53 PM »
The casting number on them.
yellercat
« Reply #3 on: February 13, 2020, 11:52:01 AM »
thanks Kevin.
Brad
52' F-1
69' Camper Special
70' F-100
88' F-150
67428GT500
« Reply #4 on: February 14, 2020, 12:41:43 AM »
C60A-8394-D    Usually a large Z on them and a "hump" on the upper back. This will also accommodate the 11.5" clutch.
        -Keith
fomocoloco
« Reply #5 on: February 14, 2020, 09:33:12 AM »
also the c5aa galaxie style and c5ta truck bellhousing. galaxie price seems to cheaper than the c60 version. i have sold a few of each. used to be that $250 was common but not now. truck bellhousing wsa 50 bucks if seller is luicky.
jim
8 65-72  f100 sb trucks 5 428's 1 460 2 521 strokers
1 66 f100 lb ranger sold
3 67-75 f350
numerous parts vehicles and parts
88 tbird 482ci 427 stroker 6R80 project
67428GT500
« Reply #6 on: February 15, 2020, 03:26:50 AM »
also the c5aa alaxie style and c5ta truck bellhousing. galaxie price seems to cheaper than the c60 version. i have sold a few of each. used to be that $250 was common but not now. truck bellhousing wsa 50 bucks if seller is luicky.
jim
Neither of the bellhousings you mentioned fit the larger clutches. The Galaxie offering also seems to have a different trans pattern.
        -Keith
« Reply #7 on: February 15, 2020, 06:33:10 AM »
jim
        -Keith
There were multiple versions of the C5AA bellhousing, it also came in a version to fit the larger clutch. Most work with the later wide toploader transmission pattern. There was a C8OE FE bellhousing too.
allen2438
« Reply #8 on: February 15, 2020, 07:41:09 AM »
Got it covered guys. Much thanks.  Allen
fomocoloco
« Reply #9 on: February 15, 2020, 10:00:31 AM »
the c5ta truck bellhousing comes with no hump but is can be used with an 11 1/2 inch flywheel , clutch and pressure plates. i still have a c5aa with the hump for the 11 1/2 inch flywheel. i have owned a few but have never seen one without the hump.
jim oberg
jim
        -Keith
3 67-75 f350
Dubs1
« Reply #10 on: February 15, 2020, 04:34:45 PM »
Hi Allen
I have  one  of the big ones  for a car/ 4 speed with the big Z on the back.  Where are you located?  Asking $400 plus the ride.
Larry   in Denver  (720)  8393477
urchinhead
« Reply #11 on: February 17, 2020, 01:04:51 PM »
Larry, I am interested if Allen has already found what he needs. Which clutch fork pivot does your Z bell have - sping or clip?
1964 Galaxie 500 Convertible, drivetrain on stand
1970 F100 Custom, 428 - body work and paint in progress
HR427
« Reply #12 on: February 17, 2020, 07:05:59 PM »
I have a c3aa car bell for sale.  Have fit a 12" under it.
67428GT500
« Reply #13 on: March 13, 2020, 05:13:44 PM »
In case you weren't aware the smaller housings will not accommodate the CF clutches. They don't clear the counterweights.
