Author Topic: Stearing arm material  (Read 10401 times)
« on: February 10, 2020, 04:57:36 PM »
Any one who knows what material there is in
the stearing arm in a 64 Galaxie?
Why i ask is to know how a shall weld it
66FAIRLANE
  • Andy
Re: Stearing arm material
« Reply #1 on: February 10, 2020, 08:22:21 PM »
I don't know about there but in Australia any welding on a steering component is illegal.
Having said that, as a Welder, I would say they would be cast steel. I would use a high nickel or low hydrogen electrode, full weld prep, pre-heat, post heat and finish peen.
pbf777
« Reply #2 on: February 10, 2020, 08:35:31 PM »
     I believe the "steering arm", or I think perhaps your referencing the "pitman arm" are generally in this era of forged steel construction, and although perhaps appear easier to weld than cast, it would still not be a recommended procedure, except under controlled circumstances, with testing to prove the result.         :-\
     Scott.
« Reply #3 on: February 10, 2020, 08:53:33 PM »
Heo why are you welding it in the first place.?
« Reply #4 on: February 10, 2020, 09:03:27 PM »
Agree that the steering arm will typically be forged low-carbon steel.
Like the others say, it can be welded with good preparation, but there are risks if you don't do it right.  What's the reason to weld?
« Reply #5 on: February 10, 2020, 09:14:49 PM »
Sorry Pitman arm. Definitely Forged steel, definitely weldable   probably illegal to weld
but so are my track width, horsepower level, noise level....
I have worked  welding components more critical than a pitman arm
so if someone can give me the steel alloy i can find out the method to
weld it. Reason to weld it is I'm changing steering box and need to modify
the pitman arm to fit the new box
« Reply #6 on: February 10, 2020, 09:48:11 PM »
4140 alloy steel?
http://ijsetr.org/wp-content/uploads/2016/06/IJSETR-VOL-5-ISSUE-6-1901-1903.pdf
This generic PDF may be of help. Good luck otherwise as most USA makers (Moog, TRW) do not list any material specs.
Btw, heating and minor (!) bending used to be a rare but doable thing. (on edit) Today, it's rat rod builders who likely do the most bending of steering componets. Never heard or saw someone welding same however on OEM builds (i.e. muscle cars) as it not really necessary in almost all cases. These days, some makers offer a host of steeering arm components that fit most rat rod builds.
« Last Edit: February 16, 2020, 10:00:13 AM by machoneman »
70tp
« Reply #7 on: February 10, 2020, 10:24:34 PM »
Pre heat , weld with 7018, post heat.    Do not rapid cool!  I do not recommend, but 4x4 guys do it all the time.  Definitely not for the unskilled as someone’s life could depend upon it.
« Reply #8 on: February 10, 2020, 10:26:07 PM »
4140 alloy steel?
This generic PDF may be of help. Good luck otherwise as most USA makers (Moog, TRW) do not list any material secs.
Btw, heating and minor (!) bending used to be a rare but doable thing. Never heard or saw someone welding same however.
I have welded steering arms before was able to get the SIS nr from Volvo
Equal to SIS 2244 then,   shall be preheated to 200-350C if my memory is corect...But don't think they used that
high alloy steel due to machining the splines. But wont hurt anything preheating "to much". Dont know if the splines is
Induktion hardened have to take a file to them and check
428 GALAXIE
« Reply #9 on: February 10, 2020, 11:17:00 PM »
Opel/Vauxhall steering box?
High nickel wire should work there are some trick wires for tic welding too.Wich you all already know  I'm sure.
Mikko
« Reply #10 on: February 10, 2020, 11:37:12 PM »
Yes, Opel Omega box. Almost to easy, one bolt hole in the right place
just have to drill two new holes shorten the steering shaft about 100 milli.
Yes no problem for me to chose the right wire/stick
If i know the alloy. I can send it for analyze if i have to
but thought if some one knew the alloy
I bet it would hold just V notch and weld it with 48.00
but trying to be serious here ;)
wowens
« Reply #11 on: February 11, 2020, 08:20:43 AM »
Pitman arms and front axles have been bent and or cut and welded for many year's by hot rodders. It was a common  fix for the result wanted back in the day. If you can determine the alloy I don't see much of a issue.
Unless it's a land speed record car.
Woody
64PI
« Reply #12 on: February 11, 2020, 09:49:20 AM »
I have cut and welded pitman arms in the past. I will drill and pin the center of the arm, V it out and triple pass it. Let it cool naturally.
« Reply #13 on: February 11, 2020, 11:44:46 AM »
Because of the application, I believe it will be either 1045 (first choice) or 5140. I doubt that it is 4140 but, what ever it is, it will have that % of carbon. As far as welding goes, the process should be about the same for all three. As a forging, 1045 is a very tough and durable steel.
I would say the weld process would be, pre heat, weld, air cool and reheat to normalize the steel. V the area, stabilize the parts and leave a ~.015 gap before welding.
« Reply #14 on: February 11, 2020, 12:27:36 PM »
I forgot to add that, the steering arm is heat treated and you'll loose that heat treatment. To see how much strength you loose, check the difference between HT 1045 and normalized.
