Author Topic: Drag Week 2020 registration  (Read 9715 times)
AlanCasida
Re: Drag Week 2020 registration
« Reply #15 on: February 24, 2020, 01:36:19 PM »
Did you guys actually type any in the form ?? Or TBD on most ?
I hand typed in all the information. Having done this before I kind of knew what to expect and I practiced ahead of time on notepad. As I have gotten older I have a tendency to transpose letters in owrds(See I did it right there!) so I tried not to out run my brain.
« Reply #16 on: February 24, 2020, 02:19:29 PM »
My son told me that there were over 400 people on the waiting list this year (as of registration day), which is quite a bit more than previous years. If that's true, then this may be the first year that the field is maxed out on participants on opening day.
Last year we heard there were close to 1000 people on the waitlist by summer, I know I saw people with numbers in the 700-900 range, and like Jeff said, when it was all said & done they only got about 360 participants that started, less than the previous few years. A lot of people have figured out signing up on the waitlist “just in case” even though they don’t intend to go. That’s what I did the last couple years. Had I won the lottery I would have been there with my new 2019 Cobra Jet lol.
I think the odds are better Hot Rod will go out of business before September than not making it into Drag Week.
« Last Edit: February 24, 2020, 02:22:15 PM by thatdarncat »
57 lima bean
« Reply #17 on: February 24, 2020, 02:32:12 PM »
HEMI Joel is in with the Coupe. See you guys in September.
Jay, and Kevin are both on the waitlist.
                         He was in at 12:04:26 as per HAMB....Plenty of time
Royce
« Reply #18 on: February 24, 2020, 03:39:08 PM »
Does the Drunk monkey have a gig for Drag Week 2020?  Holding out for more money???
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
JERICOGTX
« Reply #19 on: February 25, 2020, 07:06:31 AM »
He has a Uber ride to the event if he wants, but haven't heard if he tried to enter.
57 lima bean
« Reply #20 on: February 25, 2020, 10:23:42 AM »
         I did not enter even with the kindness of JERICO.After turning an eight dollar pizza to a
        carbon disc last night,it may be better that I leave DW to those that are capable.
Royce
« Reply #21 on: February 25, 2020, 10:47:39 AM »
Awwww  I would have thought that Joel would have asked that you at least assist him with slathering anti-seize on this wheel studs...
1992 BMW V-12 5.0
57 lima bean
« Reply #22 on: February 25, 2020, 08:07:18 PM »
                       Thats for X Honeywell people to do.
Hemi Joel
« Reply #23 on: March 04, 2020, 02:16:23 AM »
        carbon disc last night...
Try that with 2 boxes of Pizza Rolls. 1:30 AM preparing for a magnificent feast! You wake up when the smoke alarm goes off, look in the oven at your 2 dozen Kingsford charcoal briquettes, and you're still starving. So you try to cut one open to see if maybe... See Steve, I used to be a bachelor too.  (:
« Last Edit: March 04, 2020, 02:20:50 AM by Hemi Joel »
Russ67Scode
« Reply #24 on: April 02, 2020, 11:31:23 AM »
So I am on the wait list 101-200 they said.  So if I’m up at beaver springs I’ll just shoot over to see if I can get in .   So now for my question What have you guys seen fail on the FEs during this week so I know what extra things to bring I.E. rocker arms push rods etc.
Thanks
« Reply #25 on: April 02, 2020, 01:27:27 PM »
Like pretty much any engine on Drag Week, most spare parts center around the valvetrain, like rockers, pushrods, springs, and in the case of the FE, the shafts (on stock type valvetrains). I carry spare shafts, rockers and pushrods, but have never needed to do anything to the engine in the 2 times that I took the Mustang. Your engine is a whole different animal though, so I think I'd have a spare for everything in the valvetrain, except for the cam of course.
I also take a few pieces that I know you can't readily get in parts stores anymore, at least not immediately. I take an alternator, distributor and water pump. In my thinking, it's easier to take the spares, which I already have, than to pay thousands of dollars to have something overnighted. Ok, maybe not thousands, but it ain't cheap! Any more than that and I figure I'll be done, because I'm not one of those guys who will thrash to rebuild an entire engine in one night...on the side of the road. :P
Transmissions are another problem area for a lot of cars. My car isn't really powerful enough to break what I have, but your twin turbo setup may be another story.
Russ67Scode
« Reply #26 on: April 02, 2020, 08:47:25 PM »
I have a set of extra hardened rocker shafts and Dove rockers  not sure if pushrods I have are the same length
The alternator is a FORD 140 amp I can get at any parts store   I guess I’ll rebuild a steel water pump to bring, I don’t turn this engine over 6250 rpm. I actually just put a 3.0 gear in it ! Thinking valve train should survive ?  But you know how “luck” goes    Didn’t think of the distributor. That’s a FAST dual pickup,  need to think about that one !! I do have spare injectors a spare aeromotive fuel pump
