Author Topic: C4 issues - any experts out there?  (Read 4325 times)
Kevin66
« on: February 01, 2020, 04:35:21 AM »
Well, I'm back to trying to help my nephew again with his '66 289 Ranchero. This time it's a problem with his C4 transmission, and being a 4-speed man, it's not something I'm all that familiar with. Here's the story.
When he got the Ranchero, the transmission had no high gear in it. On inspection, there was no lining left on the direct drum clutches, and the others weren't much better. It needed a complete rebuild. They knew the transmission wasn't original to the Ranchero, as it was a 4-speed car from the factory. The tag on the transmission said PEE 289 6M8 B2. That date code '6M8' (Dec. 8th, 1966) suggested it was likely a '67 transmission, but several of the parts inside were dated earlier.
A friend of his, who had rebuilt a few GM transmissions, did the C4 for him. He gathered advice from several Mustang and other SBF forums, from a couple racers, from the shop manual and other books, and from YouTube. He got a good rebuild kit from Oregon Performance Transmission, which included Alto clutches and plates, Kevlar bands, the Alto reverse/high 'Power Pack' six clutch disc kit, and a TransGo 47-2 shift kit.
When it came to installing that Transgo kit, they found a couple odd things in the valve body.  The first was that the boost valve and bushing had been installed backwards, according to the TransGo instruction sheets. Similarly, there was a flat-sided disc or 'puck' there that wasn't in the instructions, and a spring that should have been there had been replaced with a check ball. Lastly, TransGo had provided a .110" drill bit and wanted a specific hole in the valve body separator plate drilled out. What they found was that the hole had already been drilled out...but more like .250"!
When the rebuilt 289 engine was fired to break-in the cam/lifters, after the obligatory 20+ minutes at 2,000-2,500 RPM, they dropped the engine to idle and topped-off the transmission fluid (ATI Super F synthetic). The rear axle had been lifted on jack stands, so that the tires cleared the ground. The trans was moved into Reverse, and the tires rotated backwards as they should. Then they put the transmission in low gear, and again the rear tires were rotating as they should. The revs were brought up to about 2,000, and the trans was shifted into 2nd gear, and the shift went quickly and smoothly. After about 30 seconds, it was shifted into high gear, and again it shifted quickly and smoothly. This was repeated a few times over the next couple of days, as they dealt with some issues about timing and idle mixture/speed.
At some later point, the engine was run again in gear, and the RPM's were brought up. As the speedometer indicated they were aproaching 50 MPH in High, the transmission seemed to literally 'fall out of gear'. The speed fell off, but the engine RPM remained the same. Only by letting the engine speed drop down could they get the transmission to re-engage. But again as speed got up to about 50 MPH (less than 3,000 RPM in High), the transmission disengaged again, and it has continued to do that ever since.
Asking some friends got them the suggestion that they install a pressure gauge, to see what was going on in the transmission. Fluid levels were again checked, and in fact indicated that it was slightly over-full. On running the engine, they saw 95-100 PSI at idle in Park. Shifting into Low they got the same reading, from idle up to 2,500 rpm or so. And again, in both 2nd and High, the indicated pressure was right around 100 PSI. In Reverse, pressure went up to about 165 PSI. Of course, this was with virtually no load on the engine, so the vacuum level did not drop appreciably.
At the moment, I'm leaning towards suspecting the valve body, given that the pump seems to be putting out at a good level. But as I said, I'm no expert. Any other thoughts about what could be going on? Thanks for any insight here.
"In theory, theory and reality are the same. In reality, they are not!"
Katz427
Re: C4 issues - any experts out there?
« Reply #1 on: February 01, 2020, 08:43:55 AM »
I had a problem once where the transmission would go back into neutral, ( seems what you describe) then when one slowed down enough it would engage first gear. This happened after changing the modulator can, and putting the spool valve in backwards. Correctly installing the spool valve , solved it.
FirstEliminator
« Reply #2 on: February 01, 2020, 11:40:45 AM »
By chance is the modulator hooked up to ported vacuum?
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
Kevin66
« Reply #3 on: February 01, 2020, 02:45:10 PM »
Thanks for the info, Katz427! I'll have them look at that valve installation.
Kevin66
« Reply #4 on: February 01, 2020, 02:48:46 PM »
No, not to 'ported' vacuum. All new hoses/lines connect the new modulator to a manifold vacuum port at the rear of the intake. Not sure if it makes a difference, but that vacuum port only connects to the 'high' side of the Stealth dual-plane manifold?
« Reply #5 on: February 04, 2020, 04:28:40 PM »
I only deal with C4s and manual VBs these days, but the notes on the VB suggest that maybe it was already modified with possibly a B&M shift kit.  TransGo is only one of many out there and they are not all the same.  66-69 valve bodies are different than 70 up also, so hopefully someone didn't mistake one set of instructions for another.  On the modulator, usually a screwed up modulator will show up as no shift or a way delayed shift into high.  Lower shifts will also be off.  I would likely source a replacement VB somewhere - stock - and test before installing a shift kit.  That may be easier said than done as valve bodies are drying up.  Same with 70 up - hard to find parts like that.  I have a stash of 70+ VBs and hording them LOL.  Sorry, no 66-69 parts.  Those are weaker than the 70 up and most development has been with 70 up.
« Last Edit: February 06, 2020, 12:06:02 PM by Falcon67 »
gt350hr
« Reply #6 on: February 05, 2020, 11:44:35 AM »
  Good eye Chris ! That is a B&M separator plate and the "puck" is also a B&M part so I agree it "had" a B&M kit. "If" the previous installer put the boost valve in backwards , that would have killed high gear clutches as originally found.
   Kevin66 ,
      "I" would go online asking for a copy of the B&M kit instructions and retrace what was done. The gold colored separator plate is supplied by B&M not a "modified" Ford plate so it will act different if a Transgo kit is used with it. To use the TransGo kit you would need a "stock" Ford separator plate from a '67-69 ONLY C4 valve body 6cyl OR v8 but ONLY those three years.
   Randy
