Author Topic: Holley Metering Block #2917??  (Read 3525 times)
ntheogen
« on: January 30, 2020, 09:19:43 AM »
I have a lone Metering block with 2917 stamped into it, can anyone help me id it? I called holley and they were zero help and i know some of you are carb gurus.  Any help would be greatly appreciated.
Jack
Re: Holley Metering Block #2917??
« Reply #1 on: January 30, 2020, 09:42:13 AM »
The Holley Illustrated Parts & Specs book lists many of the original metering block(s) under the parts lists of each carb, I’ve gone through my copy and highlighted most of the early Ford models. A quick glance found a couple matches, both secondary metering blocks - List 1982 1959 & 1960 Ford Truck with 534 engine, List 1982-1 ( Same ), List 2156 1961 1962 1963 Ford Truck with 534 engine, List 2156-1 ( Same ), List 2156-2 ( Same ).
It’s possible there are other applications, but those are the ones I have highlighted.
babybolt
« Reply #2 on: January 30, 2020, 10:22:48 AM »
Ford truck secondary block list no.s 1982, 1982-1, 2156, 2156-1, 2156-2, 2746, 6285.    534 engine.
« Reply #3 on: January 30, 2020, 10:36:57 AM »
I just put that Holley Illustrated Parts & Specs Manual in my wish list at Summit.  Got a bunch of unsure blocks around here, be nice to ID the useage.
« Reply #4 on: January 30, 2020, 11:15:03 AM »
Just a couple warnings - it’s not “easy” to cross reference the metering blocks through the Holley Illustrated Parts & Specs book that way, but it is usually possible, here’s a sample listing from that List 2156 carb. Also, for most of the real common Holleys, like the 1850, 3310, Double pumpers, etc. there were so many metering blocks used over the years they don’t even bother to list them under the parts list, just a replacement part number, so it won’t help to ID those. I mention it because the price of that book has gone up considerably since I bought mine, just want to make sure the info it contains is worth it.
ntheogen
« Reply #5 on: January 30, 2020, 04:11:40 PM »
Well thats a strange one to have laying around. Thanks very much for the assistance, I knew you guys knew more than Holley... Ha
