Author Topic: Would there be any interest in longer, aftermarket, FE journal rods?  (Read 11254 times)
I’m putting some feelers out for some potential product interest and feedback.
I’m thinking of having some rods made that would help out the guys who run 352’s, 390’s, 427’s, and 428’s by allowing them to use a shorter, lighter piston.
At first glance I would be looking at something like a 6.625-6.630 length so that the 352/360 guys could run a shelf 390 piston or even a custom 390 piston.
For the 390/427 guys, this would mean a 1.630” piston, and the 428 guys would get a 1.530” piston.
I would also be interested in looking at a 6.700-6.800 length rod with an FE journal.  I’ve done some 390’s and 427’s with BBC journal cranks and 6.800 rods, which makes for a nice combo.
I would be targeting a $400-$500 price for a set, 4340, I-beam, rated for 700 hp with a 8740 bolt.
Feedback?
gregaba
Re: Would there be any interest in longer, aftermarket, FE journal rods?
« Reply #1 on: January 26, 2020, 08:39:14 AM »
I just bought another 428 engine for a future build.
I would be interested in a 428 set.
Greg
winr1
« Reply #2 on: January 26, 2020, 08:46:24 AM »
Would be nice to have that choice
Any thoughts on size of small end and weight ??
Ricky.
« Reply #3 on: January 26, 2020, 09:36:18 AM »
Interested, Yes but if i ever get to the point using a set i dont know
FirstEliminator
« Reply #4 on: January 26, 2020, 07:32:03 PM »
The 6.7 would have been cool to have before my 482 was put together, then I wouldn't have botched the upper and lower positions of the rod bearings. Otherwise, I'm not sure of the applications.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
Posi67
« Reply #5 on: January 27, 2020, 12:31:58 AM »
I like the idea although not something I'll ever need. Price point seems more than reasonable and I'd think it could be a nice route to go for many.
driveamerican
« Reply #6 on: January 28, 2020, 08:15:07 AM »
Yes for me I have a standard bore 352 I would love to build.
BigBlueIron
« Reply #7 on: January 28, 2020, 09:56:11 AM »
At that price I think it would be a good idea. Shoot plenty of 360's still out there with the only answer "make it a 390". Some times its harder to find the 390 crank and rods than you think (for some people). Plus the cost of recon.
What would the weight comparison be, would a balance be needed for low budget/rpm stuff?
« Reply #8 on: January 28, 2020, 11:01:35 AM »
I have approached Scat and Molnar so far.  Scat said minimum custom order is 100 sets.   So that means I'm out with Scat....LOL
Molnar has replied but the pricing would be quite a bit higher than $500.  However, they are primo rods and would be lighter than about anything out there.  Still exploring options, but judging by the responses, the interest just may not be there.
« Reply #9 on: January 28, 2020, 11:07:01 AM »
If the option had been there when i asembled my 390
i had bought them
BigBlueIron
« Reply #10 on: January 28, 2020, 05:31:56 PM »
I know Blair had Molnar make some up similar to what your talking about but for a custom piston in mind. He is putting one together for me now w/360 crank. He can fill in the specifics if he wishes.
But I think It's a win, win with one part, that doesn't happen very often. Something a hobbyist or small local machine shop can order up ready to go and and utilize the good parts they already have without adding extra cost all the way to pro engine builders.
Just a guess but with Molnar reputation for light(er) rods I would wager the weight in the added length it would still keep the balance as close as anything produced as when it was new. If this where to actually be the case the price difference between Scat and Molnar would be offset by the cost to re balance.
I think most on this forum are more max performance orientated, and the benefits aren't as prevalent when you already have a 445 stroker. So the positive feedback may not be much from that type of crowd. (Absolutely nothing negative should be derived from that statement.)  Just more Mustangs w/428's and Galaxies w/427's than guys with 360 trucks.
Shoot, a stock 360 with a quench of 0.135 and 7.6:1 compression ratio to 0.041 quench and 9:1 compression ratio is a big jump for say $600 bucks. (assuming 10cc piston and 72cc head)  It would be a cheap way to make a runner out of a 360. Without adding reciprocating weight while adding a margin of safety. Plus all the other combinations it could be used in!
Got my vote Brent, but my opinion doesn't carry much weight compared to smarter more experienced guys this forum.
« Reply #11 on: January 28, 2020, 06:07:30 PM »
I've got clearance from Molnar for 6.630", 6.700", and 6.800".   I think Blair had some 352 rod length rods made up, 6.540" or so if I remember right.  The 6.630" rods would let a 352 guy run any shelf 390 piston, lose some reciprocating end weight, and go that route....or would let a 427 or 428 guy end up with a shorter, lighter piston.  The 6.7/6.8 stuff would be an option for any stock rod journal FE and would let the 352 guys end up with a reasonable short piston for a custom application.
This is one of those things where there are some guys out there doing it, but maybe just not enough to justify a batch order.  The Molnar stuff is super nice though:  super light, and come with nice fasteners.
I'd be willing to do the first 10 sets for $699 just to get them out there and test the waters.   If I can get 10 takers (I'm one of them), we can proceed.
ToddK
« Reply #12 on: January 28, 2020, 06:39:26 PM »
Would Molnar be able to do a 6.7/6.8 rod with BBC journal diameter, but FE width? If so, I’d be in for a set.
« Reply #13 on: January 28, 2020, 06:41:24 PM »
They're willing to do anything, as long as I have enough orders to make it worthwhile.
The only thing about the FE width and BBC diameter is narrowing the bearings.
ToddK
« Reply #14 on: January 28, 2020, 08:26:45 PM »
The crank in my cammer is a Ford $ steel shaft that has been offset ground to 4.00” stroke with a 2.200” rod journal. I’m currently running a BBC 6.385” rod that has been narrowed, along with the bearing. I’d prefer a longer rod with lighter pistons, no problems having the bearings narrowed again.
