Author Topic: Question for Brent Barry or Blair  (Read 5229 times)
Royce
« on: January 20, 2020, 12:17:15 PM »
Could you shoot me a recommendation for a spring for this Comp HR grind. 23562R/23564R. 2.19 intake 1,7 ex. 3/8 stem. Max rpm 5500. Stock rockers with end stands
RB
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Question for Brent Barry or Blair
« Reply #1 on: January 20, 2020, 04:32:12 PM »
325/252 with .356” lobe lift, really lazy lobe but your valvetrain is heavy.
Not looking at displacement or cylinder head flow, but focusing on the above with a 5500 rpm peak, I’d be at about 160-165 seat and 370-380 open.
Royce
« Reply #2 on: January 20, 2020, 05:27:57 PM »
Thanks Brent.. This is a 525 inch torque motor, with a less than robust valve train, hence the lazy lobe.  I wanted to get by with as little spring as possible to ease the strain on the rocker shafts.
1992 BMW V-12 5.0
« Reply #3 on: January 20, 2020, 05:39:54 PM »
I figured it was a large engine.
A small OD dual spring (1.25-1.3) or a beehive/conical will be your friend.
Those spring pressures are perfectly fine for stock rockers and end stands.
FWIW, you could have ran a lot more aggressive camshaft and still would have been safe.
CaptCobrajet
« Reply #4 on: January 20, 2020, 07:48:16 PM »
Comp 26120 beehive.  Probably should go in at 1.890 to 1.900 with what you describe.
Blair Patrick
« Reply #5 on: January 20, 2020, 07:51:07 PM »
Don't think you even need that much on the seat, but you might want a little more open.  The 5500 number should be an easy target with almost any decent dual spring, but I would also vote for the beehive/conical deal - took me a while to get comfortable with the idea of a single spring, but they do seem to work well in this sort of application.  Just be aware that on a hydraulic roller, once you loose valvetrain control it often "poops the sheets" pretty hard - - it'll be perfect at 5800 and crashing off 40 pounds of torque at 5900.  If you hear the exhaust note change at a certain RPM - stay below that number.  Or add pressure/reduce weight (titanium or tool steel retainers).
Royce
« Reply #6 on: January 21, 2020, 09:39:22 AM »
Thanks guys  that is the info I needed...
1992 BMW V-12 5.0
