Author Topic: Distributor For A Ford 226 H / 254 M Flathead Six.  (Read 3391 times)
chris401
« on: January 19, 2020, 12:29:58 PM »
I want to change the Load-O-Matic to a mechanical tachdrive distributor with a vacuum advance. Any other makes out there that have a mechanical tachdrive and can be cut down to fit a Ford?
This is for a tractor proofmeter, don't want to use the Stewart Warner crank bolt set up.
Thanks
Leny Mason
Re: Distributor For A Ford 226 H / 254 M Flathead Six.
« Reply #1 on: January 25, 2020, 01:12:56 PM »
I found a tack drive but I cant remember on the advance part I can look Monday, I am not sure what the flat six distributor is like if you have a picture that would help Leny Mason
chris401
« Reply #2 on: January 25, 2020, 08:49:03 PM »
Here is a top view of mine still in the tractor. It spins clockwise. I found a picture off of Ebay of what they look like out of the engine. The posted link here mentions a few different ways to skin this cat. An inline six Chevrolet distributor looks like a drop in with the shaft modified. I have been looking for a tachdrive 250/292 distributor, came up empty so far.
Thanks
https://fordsix.com/viewtopic.php?t=21289
chris401
« Reply #3 on: February 01, 2020, 02:54:26 PM »
Hello Leny, I called too late Friday. I found some V8 Chevrolet, Chrysler and Ford distributors with tachdrives. Does anyone know which one of these breaker cams will interchange with it's 6 cylinder counterpart?
Leny Mason
« Reply #4 on: February 03, 2020, 09:37:16 AM »
Sorry mine is a FE industrial with a tac drive You might use Your shaft in it Leny Mason.
