Author Topic: Re-Cammed Kaase/Brechler EMC MEL 476  (Read 12845 times)
Royce
« on: January 10, 2020, 12:01:12 PM »
Jon pulled the aggressive solid roller and we went with a grind that moved torque down the rpm range and has less harsh valve action..The crate from Winder Ga just showed up on the freight dock today,,  Now,  what to do with this beast.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Re-Cammed Kaase/Brechler EMC MEL 476
« Reply #1 on: January 10, 2020, 01:48:25 PM »
That’s great, it’s still a monster!
« Reply #2 on: January 10, 2020, 03:16:07 PM »
58,9 or 60 T-Bird maybe ? with serious upgrades for sure
Royce
« Reply #3 on: January 10, 2020, 03:28:10 PM »
Jay has a 60 T-bird.........
1992 BMW V-12 5.0
« Reply #4 on: January 10, 2020, 04:47:39 PM »
Or, maybe a '58 Edsel, Corsair :)
MeanGene
« Reply #5 on: January 10, 2020, 09:21:47 PM »
Perhaps my 56 Bird with a straight axle  8)
427mach1
« Reply #6 on: January 11, 2020, 08:05:32 AM »
Royce, does it only make power above 5100 rpm?   :)  Did they provide the dyno data for lower engine speeds?
hbstang
« Reply #7 on: January 11, 2020, 03:19:03 PM »
did it make more power or less with the smaller cam?cant find the results from emc.also,you have some great cars to put that in!maybe swap over to a stack injection.
Royce
« Reply #8 on: January 11, 2020, 03:26:27 PM »
If you look on page 2 of this forum you will find results from 2017 that are pretty much the max effort for this motor.. The actual EMC cam did hot have as much top end but a flatter curve than the max hp one
1992 BMW V-12 5.0
57 lima bean
« Reply #9 on: January 13, 2020, 03:22:51 PM »
"1957 Mercury 2dr Wagon "Battle Wagon" drag car  Currently engineless,  Boss 9 transplant coming soon"...As cool as this is,the MEL would be at home here.
Royce
« Reply #10 on: January 15, 2020, 09:20:41 AM »
I hear you Steve, but it would require a transmission change to fit the Bell housing bolt pattern on the MEL..  How about a 57 Custom 300?
1992 BMW V-12 5.0
« Reply #11 on: January 15, 2020, 08:11:41 PM »
I think you keep it in the MEL family of cars.
I had a '58 Edsel Corsair, when I was 19 (1963) I liked it a lot but, they are heavy (Merc chassis). My second choice would be the '58/'60, T-Bird.
57 lima bean
« Reply #12 on: January 15, 2020, 11:05:33 PM »
               Wonder wheel say's 10.20 in my 57.At my age,a fifth set of headers for the car
               and transmission case swap is a kinda a deal killer.Thank you tho....... :)
MeanGene
« Reply #13 on: January 16, 2020, 12:05:17 PM »
I have a pretty solid 57 Ranchero I'd like to move, have too many. Previous hot rod with a 390/ 4spd, has front discs and tilt column, was pulled apart for paint by PO
pbf777
« Reply #14 on: January 16, 2020, 12:40:45 PM »
     I believe there are three different bell housing bolt patterns for the MEL family of engines, and with the cubic inch capacity, I would assume the they started with the later 462 engine which used a modified bell housing pattern C6 transmission, a bolt pattern which surprisingly (was required for '68 (1/2?) Lincolns) is also present on the 385 series engines.
     Also two different block/motor-mount patterns within the decade of production.      ;)
     Scott.
