Author Topic: c6ae heads and factory ford aluminum high rise intake?  (Read 11185 times)
fe66comet
« on: December 30, 2012, 09:48:53 PM »
Got em on my 410 for my  68 SD 250 4/4 any special about them cause with the bone stock engine it is a tire scorcher.
Re: c6ae heads and factory ford aluminum high rise intake?
« Reply #1 on: December 31, 2012, 09:01:56 AM »
Just a decent combo thats all
C6AE-R heads are a good starting point and all the alum Ford manifolds work real well up to about 5500 rpm.
Combined with the 410, should be a real nice motor for a pickup
« Reply #2 on: December 31, 2012, 10:07:20 AM »
You can not technically have a aluminum high rise intake and then just bolt it on a set of c6's.
The high riser is physically to tall at the valve cover rail for it to line up.
It is maybe a mid riser or a low riser.
What number is on the intake?
The c6 heads are a lot like Cobra Jet heads only with 2.02 stock intake valves.
A set of CJ valves and some rubbing will net some good gains.
fe66comet
« Reply #3 on: December 31, 2012, 10:53:19 AM »
I was referring to carburetor position, a lot taller than the old Holley intake I took off the 445.  It is also open plenum. I would thing a duel plane would have been the intake they would have used from ford but there it is. I added larger valves when I rebuilt the engine due to the hammered up seats. Went 030 over on the bore and installed a Lunati torque cam with 9.8-1 pistons. Everything else is bone stock down to the motor craft carb . What a torque monster that turned out to be.
« Reply #4 on: December 31, 2012, 10:54:28 AM »
Any pics of the setup?
fe66comet
« Reply #5 on: December 31, 2012, 12:20:00 PM »
I can put em on FB it has no body on it now, a guy I know has a 68 2wd body I am tying to get him to part with and I know he is hungry right now. Is there a photo section here?
« Reply #6 on: December 31, 2012, 01:54:44 PM »
No photo section, but you can feel free to post photos on any of the message boards here - Jay
fe66comet
« Reply #7 on: December 31, 2012, 03:57:06 PM »
OK being a noon I haven't figured that out yet on my smart phone. I do not own a computer as it would do me no good. I live on farm out in the middle of nowhere in northern IL. I'll give it a try phones are a little limited as to what they will do.
BH107
« Reply #8 on: December 31, 2012, 10:44:23 PM »
What is the part number on the intake? To my knowledge Ford didn't make a single plane 4v intake for low riser heads. It may be a PI intake with the divider cut out, or something similar?
« Reply #9 on: January 01, 2013, 11:01:34 AM »
Hey 66
If you can email me a pic I can put it for you.
Inquiring minds want to know. lol
390fairlane@gmail.com
fe66comet
« Reply #10 on: January 03, 2013, 08:28:50 PM »
Intake is as it came it has no grind marks or anything I am not sure of the part # but will try and locate it. I have had the truck since 1983 but haven't done much to it in recent years just waiting for the perfect deal on a cab and box.
fe66comet
« Reply #11 on: January 03, 2013, 08:49:44 PM »
It does have a small divider in the bottom about an inch tall then two inches open to the plenum part # c6ae9425-8 it appears to be a medium riser port much larger height and width than the four barrel heads that came off my comet. The comet engine was out of a 68 galaxy that's all the info the PO could offer me on that one. All the date codes match on the truck and I do know the history on that. It was owned by the Rock Island Railroad then my father purchased it from them we are the second owners.
BH107
« Reply #12 on: January 03, 2013, 09:23:52 PM »
What is the suffix on the intake? 8 wouldn't be correct. Could it be an E or H? Both of those would be a PI intake. Someone cut down the divider in the plentum, but it is a dual plane intake.
Should still work well on your application.
fe66comet
« Reply #13 on: January 03, 2013, 09:53:58 PM »
Sorry - h but no machine or grind work just rough cast and monster ports, bigger than my dual quad rpm air gap. It works good though it can yank a house down with that Dana 60 in there.
