Author Topic: Lykins Motorsports 428CJ, 435 hp  (Read 5573 times)
« on: December 30, 2019, 07:13:12 PM »
Performance Summary:
      Cubic Inches:  429             Dyno brand:
      Power Adder:   Nope            Where dynoed:
      Peak Horsepower:  435 @ 5250
      Peak Torque:  482 @ 3000
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 428CJ, 4.140", 10.150", ARP main bolts
   Crankshaft brand, cast or forged, stroke, journal size: Factory 428, .010"/.010"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec, 4032, 9.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 125M10, 8-7170CH10 (Calico coated), Durabond F-33
   Piston rings brand, size, other notes:  Total Seal 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57 standard volume, Melling drive
   Oil pan, windage tray, oil filter adapter:  Canton rear sump oil pan, no tray, repop CJ adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Lykins Motorsports hydraulic roller,
    227/235 @ .050", .600"/.612", 112/106
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory
   Cylinder heads brand, material, port and chamber information:  C8OE-N, SI 11/32" valves, 2.09/1.65, bronze valve guides
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI 11/32", 2.09"
   Exhaust valve brand, head size, stem size:  SI 11/32", 1.65"
   Valve springs brand, part number, specs:  Comp Cams 914, 160 seat, 380 open
   Retainers and locks brand, part number, specs:  Comp 740
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports non-adjustable roller tip, 1.76
   Rocker shafts and stands, brand, material:  Sealed Power, POP stands/spacers
   Pushrods brand, type, length:  Trend, 5/16", .080", all different lengths.
   Valve covers, brand, type:  FMS Cobra Lemans, polished
   Distributor brand, advance curve information:  MSD, all in by 2800, steel gear
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Edelbrock Performer RPM, divider cut down and shaped
   Carburetor(s) brand, type:  Quick Fuel HR-780
   Exhaust manifolds or headers brand, type:  2" dyno headers
