Author Topic: Lot of miscellaneous parts...  (Read 4345 times)
« on: December 28, 2019, 08:52:59 AM »
Little bit of everything in here.  I'm selling it all together, as it's just a bunch of parts that have accumulated over the year.   $275 takes it all.  Included in the lot:
(5) New iron .467" distributor gears
(1) New iron .500" distributor gear
(15) Various iron/bronze .530" distributor gears
(1) New repop FE distributor with cast iron gear.  No rotor, cap, etc.  Vac advance.  Won't drop down into the block bore, don't have time to mess with it, save it before it takes a one-way flight across the yard.
(1) Ferrea 2.250" x 5.430" x 11/32" hollow stem valve, new
(2) 1.750" x 3/8" x 5.450" exhaust valves, new
(1) 1.750" x 11/32" x 5.460" exhaust valve, new
(1) 1.750" x 11/32" x 5.450" exhaust valve, hollow stem, new
(1) 2.150" x 3/8" x 5.440" intake valve, new
(2) 2.100" x 11/32" x 5.450" Manley intake valve, new
(1) 1.600" x 11/32" x 5.460" Manley exhaust valve, new
(2) SI 3/8" x 1.750" x 5.430" exhaust valve, new
(1) Full set of SI 5/16" stem valves, intake valves are 5.100" x 2.110", exhaust valves are 1.750" x 2.110"
(1) Spring/retainer/cup package, all used, but look really good.  Spring cups are 1.685" OD, will allow 1.550" spring, .635" ID.  Retainers are steel, 1.400" OD, 1.042", .700".  Springs measure 105 lbs @ 1.800", 350 @ 1.300", coil bind at 1.215".
(16) Trend 5/16" .105" wall pushrods, varying lengths from 8.900"-8.925", dyno time only, ball/ball
(16) Trend 3/8" .135" wall pushrods, 9.100", brand new, ball/ball
(16) Trend 9.375", 3/8", .135" ball/ball, new
(16) Trend 8.725", 5/16" .080" ball/ball, new
(4) Trend 8.850", 5/16", .080" ball/ball, new
(16) Trend 8.775", 5/16", .080", ball/ball, new
(13) Trend 8.687", 5/16", .080", ball/ball, non-oiling, new
(16) Trend 8.060", 3/8", .080", ball/cup pushrods, new
Eight Trend 8.775", 5/16", .080", 5/16" ball on one end, 3/8" ball on the other, new
Various other pushrods will be thrown in the box.
No warranties, implied or otherwise, buy at your own risk, all that fun stuff.
Re: Lot of miscellaneous parts...
« Reply #1 on: December 28, 2019, 10:55:40 AM »
Will accept an offer for the whole lot, or will part out.
« Reply #2 on: December 28, 2019, 03:20:56 PM »
In addition to all of those, I also have:
(1) New Blue Thunder 2x4 air cleaner base
(1) BBM Tunnel Wedge bottom cover plate
I'll take fair offers for those.
Found some more pushrods LOL
« Last Edit: December 28, 2019, 04:24:45 PM by blykins »
