Author Topic: 1966 Fairlane GT/A  (Read 8930 times)
PureStock390
1966 Fairlane GT/A
« on: December 13, 2019, 03:57:51 PM »
Performance Summary:
      1/4 mile ET:    13.13           1/4 mile MPH:103.2
      1/8 mile ET:  8.37             1/8 mile MPH:82.45
      60 foot time:1.89
      Track:Martin MI
      Weather Conditions: 60 Degrees 1000DA
Vehicle Use:
Cruiser, Show Car, "Pure Stock" Class Drag Race
Vehicle Specifications:
Model Year:1966
Model:Fairlane GT/A
Style: 2Dr. Hardtop
Engine Details: C6ME 390 Block, C7AE-B Rods, 2U Crank, Blair Patrick CP 390 Pistons, C6AE-R unported 67cc Chambers 11/32" valves, Bullet Hyd Flat .485/.485" 112 L/S 270/285 215/225, C6AE-H intake unported, C6OE Exhaust Manifolds unported, C6OF-M 600 carb, Stock GT open Air Cleaner with 3" tall element, C6OE distributor with Dura-Spark internals and MSD6AL,  2.25" crush bent H-Pipe to 2.5" mandrel mid-pipes and tail-pipes with stainless straight through mufflers.
Transmission:C6 with #9 roller bearing
Torque converter details (if automatic): Stock with roller thrust bearings
Clutch details (if manual):
Driveshaft: 3" Aluminum
U-joints: Spicer 1330
Rear end type: 9"
Differential type: Detroit Tru-Trac
Gear Ratio: 4.11
Axles: 31-spline Strange
Front tires: G70-14 Firestone Wide-Oval Cokers
Front wheels: 14x6 Styled Steel
Rear tires: G70-14 Firestone Wide-Oval Cokers
Rear wheels: 14x6 Styled Steel
Front suspension information: Stock with 289 Springs Monro-Matic Shocks, Small Block Sway Bar
Rear suspension information: H/D Leafs (replacement '69 Cobra) Monroe Gas-Magnum for front of '79 F250 4x4, Pinion Snubber
All New Build.  Went 13.70 off the trailer first run ever,  ran 13.50's rest of the day all with stock jetting, 5500 shift and 40 timing all in by 2800. Went back a few weeks later jetted the secondary up until it lost MPH, ran timing from 36-42 and ended up going 13-teens the rest of the day.
PureStock390
Re: 1966 Fairlane GT/A
« Reply #1 on: December 13, 2019, 04:02:05 PM »
Pics
« Reply #2 on: December 13, 2019, 05:20:59 PM »
She’s beautiful. Love the color.
6667fan
  • Every Second Counts
« Reply #3 on: December 16, 2019, 10:02:21 AM »
Very clean and that is awesome taking that beauty for those sanctioned rips. What is the color? I can tell it is blue but the one pic hints at a little green in it.
Nice work,
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #4 on: December 16, 2019, 12:53:00 PM »
Based on the year, I'd say it's Aqua Marine Blue? That was the color of my 65 1/2 Mustang.
« Reply #5 on: December 16, 2019, 01:07:35 PM »
sweet
« Reply #6 on: December 16, 2019, 02:07:04 PM »
My uncle had a 66 390 GTA and they used it to tow the GTO to the track. If something happened to the GTO they raced the fairlane. Just the way they drove it to the track leaving it in drive and just letting it go they say it ran a pretty consistant 14.07 they dont remember the MPH.
57 lima bean
« Reply #7 on: December 17, 2019, 01:25:37 PM »
           My guess too.Nicely done PureStock390.
Cobrajet2
« Reply #8 on: December 17, 2019, 04:22:50 PM »
Knocking on a 12.-- something pass. Pretty impressive given those manifolds. Looks like some nice cool October air, too. That always helps. A little more tweaking and it will be in the twelves for sure. Those repop tires start hooking better the more you beat the crap out of them.
Mike
PureStock390
« Reply #9 on: December 18, 2019, 05:56:23 PM »
Thanks Guys!  The color is 1966 Sapphire Blue, it was a Thunderbird only color but available on any Ford with a DSO order, it's also the same color as the '66 GT350.
« Reply #10 on: December 18, 2019, 07:23:13 PM »
Nice car. :) Respectable numbers for the combination...
